need help quick with shock install
Old Aug 25, 2002 | 10:40 AM
primer84z's Avatar
i bought some run of the mill monroe shocks and i was about to install when i figured out that the top bolt installation looked different than the factory one. the factory had a 1 saucer washer and one rubber bushing. these came with 2 saucers and 2 rubber bushings for each top part. how am i supposed to assemble these? also how tight do i tighten the nut down after i get it on there?
Old Aug 25, 2002 | 02:07 PM
82camaro's Avatar
Car: 82 camaro SC
One washer and rubber bushing goes under the top mount and the other goes on top of the top mount(all you are looking at is the top bushing and washer. When you remove the old shock, make sure the old bushings aren't stuck. Stick a washer, then a bushing on top of the shock. Put the shock though the hole and install the bushing then washer, then the nut. Tighten until they sqeeze the bushing a bit.
LT1Formula
Nov 16, 2015 01:13 PM
crazynights
Aug 21, 2015 06:53 AM
TheJoeY88
Aug 13, 2015 06:51 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
