Car doesn't stop unless floored
Old Aug 25, 2002 | 12:43 PM
TurBo BirD's Avatar
Car: 1989 Pontiac GTA
Engine: 3.8 Turbo
Transmission: 200r4
I have an 89 GTA, 4 wheel disc. I have to floor the car for it to come to a stop and it wants to roll when I do that still. I think its air in the lines...What else could it be?
Old Aug 25, 2002 | 01:08 PM
ede's Avatar
ede
unless you've had the system open air didn't get in. have you bothered to look for leaks or check the condition of the pads? might be a good place to start.
Old Aug 25, 2002 | 01:47 PM
TurBo BirD's Avatar
Engine: 3.8 Turbo
Transmission: 200r4
changed all the apds already, changed the fluid last week and bled them. The fluid was brown and had alot of particles in it.
Old Aug 25, 2002 | 03:55 PM
ede's Avatar
ede
i'd be checking the soft lines then
Old Aug 25, 2002 | 09:24 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Sounds like your master cylinder has gone out. I had the same problem in my Lincoln.
.....by stating "to the floor" you're implying that the brake pedal is touching the floor board and you're practically standing on it??...if that's what you mean, then it definately sounds like your master cylinder is KIA.
Old Aug 25, 2002 | 10:50 PM
TurBo BirD's Avatar
Engine: 3.8 Turbo
Transmission: 200r4
I am holding the brake to the floor and it slowly rolls to a stop
Old Aug 25, 2002 | 11:08 PM
Car: 91 RS
Engine: 350 TBI
Yep, you need to send out a search party for your master cylinder.
....someone else back me up here.
Old Aug 27, 2002 | 08:24 PM
Mike91rs's Avatar
Gunny's right
Yea man you need to check your master. Are you losing fluid fast? Quick test might be to park her after a drive and check to see if you're leaking out from the rear. Might I sugest you look into steel lines as well. if your lines are starting to colapse, that will also cause you problems. I'm getting to that point myself....
Old Aug 28, 2002 | 01:39 PM
TurBo BirD's Avatar
Engine: 3.8 Turbo
Transmission: 200r4
IM not losing fluid. I think the E brake line isnt adjusted right.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
hokis
Aug 9, 2015 03:57 PM
killer777
Aug 8, 2015 02:47 PM
