Alignment
Old Aug 26, 2002 | 05:30 PM
zach's Avatar
Alignment
What are the alignment specs for an 85 trans am? I took the car to SEARS for an alignment and then took the car on a trip about 700 miles and when I got home there was wear on the outer edge of the tires. You can see a noticeaber grove that was not there before the alignment.
Thanks.
Old Aug 26, 2002 | 06:45 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
http://www.fl-thirdgen.org/alignmentspecs.html
here is a list of alignment specs for thirdgen f-bodies. but personally, i would have them set the camber to 0 to -.5 degree and toe to .010 degree total.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
evilstuie
Sep 24, 2015 02:31 AM
89 formula TPI
Sep 20, 2015 10:54 AM
