Phoniex V12 Question/Problem
Old Aug 26, 2002 | 08:53 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i most recently purchased a V12 injector w/smart pak. everyone said it worked and had great results around here. i said what the hell and bought it. well the problem i'm having is the when i squeeze the handle down it won't come back unless i pull the handle back. the fluid aerates in the little clear cylinder since the movement is sudden and violent. this defeats the purpose of the product. there is no air the suction line what so ever or the cylinder until it comes time to pull the handle back. i thought the handle/trigger was supposed to retract to it's original "unsqueezed" postion? it remains in the "squeezed" postion??? please tell me i'm doing something wrong and that this can be corrected easily.
edit: when i pull back the handle it "jumps/jerks" back. it doesn't move smoothly back as i thought it should???? please help
Old Aug 27, 2002 | 05:31 AM
ede's Avatar
ede
have you tried movingthe adjusting wheel in front of the suction line? other than that i might think you got a bad one. did you get a video with it? i did, watch it if you did, lot easier than reading the instructions.
Old Aug 27, 2002 | 07:10 AM
Car: 1988 IROC-Z
i have tried the adjusting wheel. same thing except it gets stuck in the max travel postion for that number(only when fluid is present). it does not get stuck when there is no fluid in the injector. although the injector still does not retract smoothly. it only slighty "vibrates" when returning to it's "unsqueezed" postion. i have looked at the video and i am stuck at the bleeding of injector part. i wish my injector would work as smooth as those in the video . why dod i always get the bad stuff???
Old Aug 27, 2002 | 08:32 AM
ede's Avatar
ede
never had any problems with mine, used it as a preasure bleeder. maybe you do have a bad one. call them, i've talked ot them before i bought mine and they seemed pretty good to talk to, or take it back to where you got it.
RockinGTA89
17
Nov 9, 2003 11:02 PM
Andy Fanshawe
Sep 22, 2003 05:13 AM
camaro6spd
Car Audio
Nov 16, 2002 10:13 AM
BlueAlice91bird
Car Audio
May 11, 2002 09:10 PM
