SQUEAK squeak squeak
Old Sep 4, 2002 | 07:25 PM
squirrelybird's Avatar
okay so i have this squeak when rolling....sounds like directed from front wheel area....sometimes it squeaks, sometimes it doesnt.....usually stops while brakes are applied (not pad wear sensors though)...i just greased front end stuff. name that squeak!
Old Sep 5, 2002 | 05:04 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Steering box loose?
What year is the car?
Thanx,ANDYZ28
Old Sep 5, 2002 | 07:15 AM
ede's Avatar
ede
bounce the front end while sitting still and see if it does it. if so look at the control arm bushings and struts. might want to spray the back of the pads with anti noise stuff
Old Sep 5, 2002 | 10:15 AM
pianiy's Avatar
Start eliminating things... anything that rotates. Wheel bearings, rotors, brake pads, calipers, etc. Its really not that hard to pull the wheel and inspect whats happening.
Old Sep 5, 2002 | 12:12 PM
ede, im thinking this is a spinning part making my squeak. andy, its a 91 bird. oh yeah...i have an idea....tell me this, how should your pads line up on the rotor? my mechanic changed mine without asking first (he is a family friend) when he changed my water pump. i checked them out and they stick out over the edge of the rotor a little. maybe the squeak is the hangover rubbing the side of the rotor? or is it supposed to be like that?
thanks guys
Old Sep 8, 2002 | 09:09 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If you are referring the "Wear Sensor" on the pads, no they are not supposed to contact the rotor. It's time to replace the pads.
Lon
Old Sep 8, 2002 | 12:11 PM
no, not the wear sensors, lon, the actual pad isnt completely on the rotor--it hangs over the side a little and because of wear, there is a lip dug in the pad that hangs over the side of teh rotor.
Old Sep 8, 2002 | 12:30 PM
lonsal's Avatar
I doubt that is the source fo the noise. But you can take out the pads and send them on a belt sander to remove that ridge. It will also take any glaze off the pads from overheating. Warpage of the rotors may also be the source of the noise.
Lon
elevario
Mar 1, 2002 12:10 PM
elevario
Aug 9, 2001 01:42 AM
crazeinc
Jul 30, 2001 11:58 PM
zedder 1 9 9 0
May 16, 2001 07:20 AM
andrew350
Dec 7, 2000 05:12 PM
