Creaking noise when front suspension flexing
Old Sep 11, 2002 | 01:33 AM
Connan1's Avatar
Car: 1992 Camaro RS
Engine: 5.0 Liter V8 TBI
Transmission: 5-speed manual
The front suspension on my stock 92 RS just started creaking like the floorboards of an old haunted house today. I first noticed the creaking noise after going over a few small speed bumps in a shopping center. I shut the engine off, got out of the car, and bounced the suspension by pushing down on the car above the front right and front left wheels. And there’s that creaking noise again coming from both sides.
My guess is that the springs and/or the shocks are making that noise. I hope you guys tell me that if I shoot some WD40 or grease at some key locations the noise will go away.
Your thoughts are appreciated.
PS: The car is approaching 99k miles.
Old Sep 11, 2002 | 06:26 AM
SLOW5.0's Avatar
might be the lower a-arm bushings or sway bar bushings. I have the same creeeeck from mine
Old Sep 11, 2002 | 02:41 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i would have to say the bushings also. try to pin piont the origin alittle better. have a friend move the car and you listen for the noise. good luck.
Old Sep 12, 2002 | 03:44 AM
Connan1's Avatar
Car: 1992 Camaro RS
Is it common for the front suspension on our cars to make this noise at about 100k? Given that they are very nose heavy.
Do you just live with the noise SLOW5.0?
Old Sep 12, 2002 | 07:40 PM
SLOW5.0's Avatar
Yep.... All things break down with age. Fords, Chevys, Mopars.. Its going to happin no matter what you do. But it can be fixed.
Old Sep 12, 2002 | 10:16 PM
Connan1's Avatar
Car: 1992 Camaro RS
Even Beemers and Benzes?
Old Sep 12, 2002 | 10:50 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
You guys aren't alone. Mine does it too. Must be a popular trademark. Mine's got over 150,000, so I guess I'm due. I was hoping that a good chassis lube would cure my problem, but the source of the groan is nearly impossible to find.
Old Sep 12, 2002 | 10:57 PM
AFrikanGoodTime's Avatar
Check your frame for cracks behind the steering box, they are prone for cracking there and it will make a creaking sound. If it is cracked, get it welded of course but then add a steering box brace (aka-wonder bar). The wonder bars came stock on the Irocs because of added stress of larger tires.
customblackbird
Aug 15, 2021 10:16 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
cam-mike
Aug 24, 2015 07:23 AM
