tires for stock rims?
Old Sep 16, 2002 | 01:24 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
Transmission: TH700 R4
Axle/Gears: 3.08 drum
Would anyone be able to tell me how wide stock rims on an 85 z28 would be? I'm trying to figure out what size tires I should put on my rims. I'm thinking p235/60 r15's on the back and p215/65's in the front. i'd like to put the widest possible in back while staying with the stock rims and not having to make any additional clearance for the tires. I'm also not getting anything too expensive, just BFG Radial T/A'S.
Old Sep 16, 2002 | 02:37 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
85 z's only came with 15" rims?...Didnt they come with 16" rims? well if your Z atcually came with 15" rims then its probably 15"x7" rims. Are you going to be drag racing? or taking turns? if your gonna be drag racing you can fit 235's on the back but if your gonna be taking turns thats gonna roll way to much.
Old Sep 16, 2002 | 03:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
85 Z with 15 inch rims are 15 x 7. Most all rims (that I have seen) have the sizing stamped on the back of the rim.
Old Sep 16, 2002 | 04:11 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
alright, thanks
Old Sep 17, 2002 | 10:20 AM
Joey1986Z's Avatar
Car: 1986 Z28
Engine: Code "H" LG4
Size Matters
For the 15X7", the standard tire is 215/65/15
Optional is 235/60/15.
Any should work fine.
Old Sep 17, 2002 | 10:25 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i have seen 295's stuffed under there, but i don't recomend that
right now i have 235/60/r15's on all 4 corners, it is descent for handling even though someone said earlier it wasn't but with my suspension i need a bit of give in my tires. i had alot of luck of 225/60's on my car in the past you might try to find a set of those they fit very nicely.
Old Sep 17, 2002 | 10:40 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
thanks for all the advice. i got my tires today. 235/60's rear and 215/65's front. I think they look pretty good. havent put them to the test yet. wont do that til i register the car and insure it in a few days. next thing is a paint job for my camaro... :lala:
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Randomtask2
Aug 13, 2015 01:57 AM
Exxon Limited
Aug 9, 2015 08:13 PM
