Brake Problems
Old Sep 18, 2002 | 05:03 PM
Casey'91Z28's Avatar
Brake Problems
When I am going down a hill my front end kind of shimmys when I am on the brakes. If I am going fast and get on my brakes it will shimmy pretty hard and pull to the right. Another weird thing it does is when I am coming to a stop I can fell the pads grabbing an releasing slightly. I suspected warped rotors but when I went to check the brakes the caliper piston was extremely hard to put back in place I had to use a c clamp to get it to go back in. What are the symptoms of bad calipers? So is it possible that I need new calipers as well as rotors. While I'm at it might as well replace the hoses and put some new pads in right?
Old Sep 18, 2002 | 05:24 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
You are correct.
Thanx,ANDYZ28
Old Sep 18, 2002 | 09:07 PM
Another thing I forgot about is that I bleed my brakes about a month ago so I don't think there is anything blocking the hoses.
Also any suggestions on brands I should get. I don't want Performance Friction Pads because I think they are part of the problem.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
