Strange sound, coming from front wheel
Old Sep 19, 2002 | 07:03 PM
JPrevost's Avatar
Car: 91 Red Sled
I don't know which it is but when I'm turning left my front right wheel makes a scratching sound. If I slow down and go straight it's still scratching. When I crawl it makes the same sound but it only goes with the wheel once a revolution making me think that it is definatly a brake problem. I checked the pads and rotor and both look fine when still. I'm going to jack up the car tonight and spin the tire to see if it's a warped rotor, although I don't feel it at ALL in the pedal. The car doesn't pull to a side and the braking works great. I was under the impression that if a pad was low that the scretching was constant, any ideas? Maybe a wheel bearing (gonna look at that too tonight).
Old Sep 19, 2002 | 10:47 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
You may have something stuck between the rotor and the pad. Or you may have a defect in the pad. I had the later, the pad had a peice of metal that must of got formed into the pad, as soon as I had worn the pad down to that layer, it made the most annoying scratching noise.
Old Sep 21, 2002 | 03:36 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
do third gens have a rock guard? Out old taurus did it because of that, or could be that the squealer is is bent to close to the rotor. Other than that I don't know.
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
db057
Aug 22, 2015 08:17 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
