anyone ever install a ford 9 inch
Old Sep 25, 2002 | 01:43 AM
transam84's Avatar
has anyone in here ever put a ford 9 inch in there third gen?? I have heard that you have to get a dif or custom drive shaft and that the stock one won't work. if anyone has any info on this (not narrowed, stock width) upgrade I would be thankful.
Old Sep 25, 2002 | 04:39 AM
ede's Avatar
ede
lot of people have, take a look at moser and see what they have to offer
Old Sep 26, 2002 | 05:15 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Yes,the Moser 9" is a very good piece of kit.It comes with axles which will handle 800hp.You will need a custom made driveshaft and brackets for the swaybar and spacers for the lca's.It's not quite the "bolt on" they make out,but not far off and definately a good upgrade.
Old Sep 27, 2002 | 12:43 AM
transam84's Avatar
ICA's?? what are the ICA's. sorry for the dumb question lol.
Old Sep 27, 2002 | 06:59 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Change your font. It says LCA. Lower Control Arms.
Old Sep 27, 2002 | 07:41 AM
1987gta's Avatar
I went with a Currie unit and it was a direct bolt in. I dont its necessary to cut anything, but then again I had everything cut for the 6 speed anyway. I havent been on their site in awhile, but they should still have it available. Hope this helped
Joe
Old Sep 27, 2002 | 04:29 PM
gtabadboy's Avatar
I bought the moser rear. Its a great rear end and bolts right in. All that you need to buy is 18 nuts, gear fluid and you need to get a new u-joint for the driveshaft. I picked up the u-joint for like 30 bux. When you take off the old u-joint from the driveshaft, you have to heat it up with a torch. There is nylon holding it in. It takes a while but it will melt and ooze out. The driveshaft will fit fine.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
mustangman65_79
Car Audio
Sep 30, 2015 09:37 PM
kyleb24
Aug 15, 2015 08:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
