Installed Jegster sub-frame connectors!!
Old Sep 25, 2002 | 07:46 PM
TA-Wizard's Avatar
Car: 1988 GTA Notchback
Engine: 5.7 TPI
Transmission: TH-700R4
I just finished installing the Jegster SFC's. All I can say is WOW!! what a difference.
The significantly reduced cowl shake, jounce over bumps, and rattles is amazing. I am not regularly impressed by performance parts, but this product is impressive in the difference it made. The fit to the car was outstanding...nice and tight up against the sill lip, with nothing visible below the car. They bolted right up. I have a 3-inch Flowmaster exhaust and there is at least a 1.5 inch gap between the SFC's and the exhaust.
I did not have to hassle with the exhaust at all!!!
Another thing is that they are precisely the correct length in order that the bolt holes align to the factory welded seam of the front sub-frame. The bolts go right where the metal is the thickest....very well engineered.
Installation took about 2 hours, after which I went down to the local performance exhaust shop and had them welded in. The guy at the shop said that they were the best SFC's he has seen yet for F-bodies. He asked me where I got them, and when I said Jegs, he picked up the phone and called and ordered 5 sets right there in front of me!! He said that he gets a discount from Jegs, and that he could sell them installed for $400.00 all day long. He even did the welding for free!!
Unlike other SFC's, the Jegster's fit tight up against the sill lip. This enables them to be mig-welded to the reinforced area of the sill plate without having to take up the carpet!!! This alone is worth every penny of the $179.99 they cost.
I know this sounds like I am a Jegs employee, but, I have had a lot of performance cars over the years, and I have lost count the number of times I have ordered a 'bolt-on' product only to cut, bend, grind and cuss before it fits up. I know that making SFC's is not rocket science, but it is nice to see a well crafted product that performs as advertised and at a good price.
The GTA I just purchased is the first third-gen GM car I have owned. The obvious question now is, why in the hell did GM not install something like this on these cars from the factory!! It boggles the mind how much more satisfying it is to own a car that feels solid and planted, and that makes you want to go out and by another car from GM. I have heard a hundred stories about how these cars sound like a bucket of junk inside from all the groans, rattles and squeaks, about how they crack above the door jambs, etc........a couple pieces of boxed steel makes them go away??? Hopefully GM has learned a few things since 1988.
Old Sep 25, 2002 | 08:21 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
nice, i wonder how they compare to sphons new ones
Old Sep 25, 2002 | 09:09 PM
TA-Wizard's Avatar
Engine: 5.7 TPI
I can't imagine how they would be better, the Jegs units look stock they fit so well.
Old Sep 25, 2002 | 09:19 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
How did they feel before you got them welded on?
Old Sep 26, 2002 | 08:39 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
can you post some pics?
hmm I need to get me a camera real soon, before i start doing work anyway, so I can catalogue my changes.
Old Sep 26, 2002 | 06:41 PM
pianiy's Avatar
I was wondering the other day about the same things with GM but its inherent with the unibody design that there will be rattles and cracks from its weak design. All in the name of saving money and materials thats why there aren't any reinforcements because they were trying to get away from the frame on body design.
I noticed though that I never heard any kind of frame rattles or whatnot in my dad's 84 Olds station wagon - simple reason - its body on frame design. You're basically just framing up a unibody which is an oxymoron.
Old Sep 26, 2002 | 08:34 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
I need a set of them too my car squeaks so bad and I can feel it flexing under stress just when I punch it.
Old Sep 27, 2002 | 11:45 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
jeg's SFC's
i have them and they made a big difference now if i can just find that mystery rattle i have i would be set
Old Oct 1, 2002 | 10:15 PM
atomicm0nk's Avatar
do you have any pictures, or dimensions of these connecters, my brother is a welder/metal worker and would like to attemt to make a set for my 86 t-top
Old Oct 2, 2002 | 08:15 AM
roxieshotrod's Avatar
Car: '91 RS
Engine: 383
Transmission: Turbo 350
Re: jeg's SFC's
Hey! the mystery rattle! I have that too
I was hoping sfcs would take care of that, darn. well, i need them anyways, i fell like the wheels are gunna come off even now when i gun it, in a week or so, when i have 400+ lbs of torque hehehehe (old motor is pulled, new one to be set in tonight!!!) im really going to feel like the thing is falling apart. its on my christmas list, although i may just buy some now, dont know if i can wait til next spring to put them on!
MORE POWER :hail:
Old Oct 2, 2002 | 11:54 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
ok
if you have the mystery rattle and dont have SFC's then i know its not cause of them ......and as far as it goes i gave up till it breaks ir falls off i wont be able to find what it is someon told me it might be my hatch ..... but who knows
oh and i dont have any pictures of the SFC's installed
Old Oct 2, 2002 | 04:30 PM
Car: '91 RS
Engine: 383
ok so i checked out my jegs catalog, im assuming you got the "bolt-in frame ties" (#550-40053) and had them welded on? im assuming so b/c its the right price and everything. my mystery rattle sounds to me like loose ground effects or something but nothing seems to be out of place. I too have resorted to waiting and watching my rearview for something falling off. Im guessing the dumb thing is just gunna rattle forever though. BOO I hate that.
Old Oct 2, 2002 | 10:50 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
yeah
but i havent gotten around to welding it yet i have to order some por 15 to cure a little rust then ill weld them
Old Oct 6, 2002 | 12:39 AM
BitchinRS's Avatar
If you still have your stock brake calipers you may want to check them. My '92 RS has a hard to track down rattle. I found that it's the caliper bouncing around on it's bolts. Aply a small of brake and the noise stops. I'm assuming that the bolt holes are worn which allows it to hop around a bit.
Old Oct 6, 2002 | 09:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Pads can rattle in the caliper too... makes a fairly loud noise.
Old Oct 6, 2002 | 11:09 AM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
ive been
down that road already my mystery noise sounds like part of the body is gonna fall off i replaced al my calipers now im starting to do the bushings etc etc
Old Oct 11, 2002 | 05:01 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Re: Installed Jegster sub-frame connectors!!
I had a similar experience with my Spohn SFCs. What a difference!
Thanx,ANDYZ28
Old Oct 11, 2002 | 09:29 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
pics would be cool, to see what the connectors look like and also of where how they mount onto car exactly.
hmm
Old May 20, 2012 | 06:46 AM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
I've heard ( not sure if it's true ) back in the day factories used to put a marble or ball bearing in a portion of the car and seal the ends up so there is a constant rattle, just to have the car continually in the service department to be fixed. After numerous parts replaced the rattle is still there, only to be told it's probably something else.
maybe it's an urban myth, but I swear some cars have a handful of the bearings hidden somewhere.
Old May 22, 2012 | 09:58 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
When I worked at the chevy dealership, we got a van in that had a horrid rattle..... after taking apart the rear doors, the tech found a coke can, with a few rocks in it, suspended from a string...... there was also a note: "How long did it take you to find this one?".....
Old May 22, 2012 | 11:13 AM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
Holy crap. Thread resurrected after almost a decade.
Old May 13, 2014 | 09:47 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
sorry to bump this thread again but that is hilarious!!!
Old May 16, 2014 | 07:22 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I thought I was in a Time Warp. At about that time frame I had the then new Spohn tube type SFC installed. After all this time my 87 IROC-Z28 is still tight and rattle free.
Best investment I made on my car,
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
toronto formula
Nov 10, 2015 06:17 AM
djmarch
Aug 19, 2015 12:07 PM
