swapping 9-bolt discs over to 10-bolt....anyone done?
Old Sep 30, 2002 | 07:23 PM
shannon's Avatar
after dragging home a complete 9-bolt posi/disc with 2.77s for $125. yesterday, thinking a simple gear swap up to 3.42 was a good deal......then finding out that gear swap will cost more than I can build my complete 10-bolt for......Im thinking.
Has anyone taken the disc brake system from the 9-bolt and put it on a 10 bolt? Did some measuring for the bracket/backing plate bolts and they seem to be off 1/4". I'm thinking this should be no big hurdle and looking for opinions or experiences of others.
Thanks,
Shannon
Old Oct 1, 2002 | 07:45 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The disc brake setup on the pre '89 rears is not too desireable.
I would suggest you try to sell the rear you have, and start over.
Ed?
Thanx,ANDYZ28
Old Oct 1, 2002 | 03:08 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Here....and I don't need another 9 bolt, unless someone has a 3.45 with a good posi available....cheap.
I saw in another post that you said it's an '86 9 bolt...correct?
If so, those (disc) brakes suck. Your best bet is to find a set of 9 bolt backing plates (Andy is getting them made.) and install a set of '89-up PBR brakes on your 9 bolt as seen below.
Old Oct 1, 2002 | 03:20 PM
ebmiller88's Avatar
Here's my rearend...(insert jokes here)...
Attached Thumbnails swapping 9-bolt discs over to 10-bolt....anyone done?-all-set-1-.jpg
Old Oct 1, 2002 | 10:40 PM
laiky's Avatar
when i swapped the 10 bolt from my 84 with factory 4 wheel disk it was a direct swap to the 9 bolt. I don't recall any problems at all, but it was 10 years ago
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
