tieing frame together
Old Oct 13, 2002 | 06:36 PM
StylnCamaro's Avatar
Every now and then I'll see comments like"re-enforced frame" and I had my frame "tied together" so it won't twist...What is meant by these 2 terms?
Old Oct 13, 2002 | 06:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Usually subframe connectors... most of us consider them to be something that belongs there, but the factory forgot to put on.
Old Oct 13, 2002 | 07:40 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
SFC's are suprisingly cheap. I'd expect them to cost more for the increase in chassis stiffness they provide. They are definitely on my list of things to add to the car...thats after I get an engine in it though.
Old Oct 14, 2002 | 10:12 PM
MdFormula350's Avatar
uni-body cars like the f-body have some flex in them
to stop most if not all the flex people have come up with some great ideas..
like sub frame connectors, strut tower bars, wonderbars..
these items can really produce a more solid frame, and therefore more power can be put onto the frame and thats a good thing
with out damaging it..
Old Oct 15, 2002 | 03:16 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
SFCs completely change the car. Stock you can FEEL the car twisting when you take turns. But after the SFC's that twist is all gone. Also it takes away alot of road rattles.
Old Oct 15, 2002 | 04:48 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Yea, stock, our frames suck. Heres a way to see it. Open one of your doors, then push it shut, but dont let it latch or close all the way. Now jack up a wheel on the same side as the open door, and watch how the door doesnt line up anymore. Just something i noticed on my car one time...
Old Oct 15, 2002 | 08:22 AM
FruityOne's Avatar
I noticed that when I had the car up on Jack stands to get the last few header bolts out. No matter what I tried I couldn't adjust the jack stands to straigten out the frame. Kinda scary if you ask me.
Old Oct 15, 2002 | 06:37 PM
would the lca's do just about the same thing or are they different
Old Oct 15, 2002 | 07:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, a different thing... LCAs are what connects the rear end to the car. They're weak too, just not as weak as the stock car body. SFCs reinforce the body itself. You'll get to where you'll need better LCAs eventually as you continue to add power. But SFCs are the first thing you'll need.
Old Oct 15, 2002 | 08:04 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
Yeah I've seen some older muscle cars twistin really bad because they had so much torque pushin through em. SFCs are good
Old Oct 15, 2002 | 08:12 PM
how about k-members and a-arms what do these two do for the susp./chassis and are they worth it
Old Oct 17, 2002 | 11:08 AM
N8Miller's Avatar
how much would a decent set of SBCs cost---about $80 or so? where is a good place to get them?
thanks
Old Oct 17, 2002 | 01:16 PM
FruityOne's Avatar
One image says it all. And yes, you can click on it.
Ed1LE
Sep 30, 2018 09:14 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
