Sway bar combo? 36mm / 21mm Any good?
Old Oct 15, 2002 | 09:08 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Will the combo of 36 hollow bar up front and a 21 mm Iroc bar in the back be any good? I am trying to improve the 30/18 bars in my v6 camaro.
Old Oct 15, 2002 | 09:35 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
that combo will understeer pretty badly.
the 24mm bar is what came from the factory with teh 36mm front bar.
Old Oct 15, 2002 | 11:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Dewey is correct.
JamesC
Old Oct 15, 2002 | 11:51 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
where can I get a 24mm bar?
Old Oct 15, 2002 | 12:03 PM
JamesC's Avatar
This is not a direct answer to your question, but my reply may make finding the bars more easy.
Some 89-92 Camaros and some 86-92 Firebirds were equipped with the 36/24 mm combo.
JamesC
Old Oct 15, 2002 | 12:09 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I realize that however all the junkyards I have called around me do not have any of those cars left in the yard and honestly it is hard to find any car older than 95 or so in the junkyards around here.
Does anyone have one for sale that is DEFINATELY a 24mm?
Old Oct 15, 2002 | 12:32 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i would check the classifieds.
aslo check the venders at the top of the page, a couple of them sell used parts, one of them might have it.
also spohn sells an aftermarket 25mm rear it will actualy work very well with the 36mm front bar, since GM designed these cars to have some understeer. (so stupid drivers don't wreck ). a 25mm rear bar "should" give you car a VERY neutral feel (may feel loose if you are used to the understeer that is built into our cars)
Old Oct 15, 2002 | 08:56 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I was at the wrecker and came across a rear bar on a '82 Z28, it turned out to be an aftermarket 1 1/8" (about 28 mm) monster.
I just mounted it last Saturday and it's the best suspension mod I've done yet. Keep your eyes open for one of these puppies.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
