Question About Borg-warner 9-bolt
Old Oct 15, 2002 | 12:13 PM
89Rock's Avatar
I have a question about the borg-warner 9-bolt. i have an 89 IROC w/ a 350 TPI. i was underneath my car the other day and saw on the rear end "Borg-Warner". I was shocked. I had no idea i had a borg-warner rear end. i have heard many stories about it, and i didnt have a clue that i had it. my question is: is it posi-traction, and what is the gear ratio??? i know there is supposed to be a tag on the rear end, but i dont know if there is a code that tells you the ratio or not.
i also plan on beefing up my 350 or dropping a big block 454 in it later, so will the BW 9-bolt be strong enough to handle the horsepower???
thank you for the help
Old Oct 15, 2002 | 12:18 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Welcome to the boards and the 9 bolt club.
Can you get the RPO codes from your car? Look for G80 denoting limited slip (IE posi) and G92 denoting the performance ratio. Otherwise, you have the 350 so you probably got the 2.77 rear like the rest of us.
Ed
Old Oct 15, 2002 | 02:57 PM
chacane67's Avatar
454 huh? You ever seen a grenade go off inside a differential?
Old Oct 15, 2002 | 08:20 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
He may not have but the question is, have you?
Old Oct 15, 2002 | 08:40 PM
Tom Keliher's Avatar
www.9bolt.com
The owner of the above site, Miles is a member here. Has been running a 427BB 500HP Chevy in his 3rd gen for over 3 years drag racing it on his BW 9-bolt. No problems.
Old Oct 16, 2002 | 01:10 AM
chacane67's Avatar
He is one, of very few......
We in the diff business call the GM Gov Lock a "Grenade lock". A few years back, one of the Border Patrol SOV's (special op vechicle) came in on a hook, and upon looking at what once was a cover was no more. The little 'watch' parts and the carrier itself in the Gov Lock...well basically exploded upon landing from the "air" they caught on the way back to the station.......so yeah I guess I can say I have.
Old Oct 16, 2002 | 02:54 AM
CrazyHawaiian's Avatar
Car: too many ...
What are the official max hp/tq #'s the 9 bolt can take? I see everywhere that they are stronger than 10 bolts but I never see any numbers. Just curious.
Old Oct 16, 2002 | 06:16 PM
chacane67's Avatar
I have never seen any advertised numbers either, but rest assure you can brake anything with enough power. A 9-bolt and a 7.5-6" 10 bolt are pretty close to the same, but the 9-bolt does have press-on axle bearings, so in effect it is already stronger. I have seen both live with 600 RWHP.....there is a guy over in Phoenix Az. that works at one of those automotive institutes, I think it was a 95 F-body, it WAS impressive!!!!! And for the 9-bolt theres a couple of Cats here with Big Blocks makin some real numbers too........
Old Oct 17, 2002 | 07:11 AM
ausrs's Avatar
suppose the answer to that would be to get in touch with borg warner and ask them ...hard to do i realise i believe spicer own them now (whoever spicer are )
Old Oct 17, 2002 | 06:03 PM
chacane67's Avatar
DANA Spicer
Old Oct 17, 2002 | 10:24 PM
laiky's Avatar
i had this "gov lock" in an 84, until it broke. i replaced it with a regular 10 bolt unit. This was the best driving, handling and overall performing posi i have ever driven. Does any body have any info on how they work?? where to get them??
Old Oct 17, 2002 | 10:55 PM
chacane67's Avatar
Get what? A gov lock or an Eaton type?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
