Wtf?
Wtf?
Are coil spring isolators and coil spring boosters the same thing? I don't know what a isolator looks like but a booster is one solid piece that kind goes in the middle of the coil I guess. This is messed up. NOBODY in town carrys them. Need help quick.
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Nope. Isolators go on top of the spring - between the spring and body. You should be able to get them from a GM dealer and they are not expensive at all.
-Schultzy
-Schultzy
Car: 1989 GTA
BTW - the isolators for the rear springs look like big rubber donuts without the hole!
Hope that helps somewhat.
-Schultzy
-Schultzy
Car: 1989 GTA
Re: isolators
Originally posted by AFast83z28
what about isolators for the front? would the isolators for a 92 z28 fit a 83 z28 cuz they said they dotn carry nothing pass 1990 freaking idiots
Anyone else?
-Schultzy
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
-Schultzy
-Schultzy
Engine: TPI 305/ v6
Sometimes the grey-matter isn't all it used to be...
(and sometimes that's a good thing...
They (the rear isolaters) sort of look like that wax ring for a crapper...
)They (the rear isolaters) sort of look like that wax ring for a crapper...
Engine: 305 TPI (LB9)
Transmission: WC T-5
The front ones look nothing like the rear (other than the fact that they are round). They are thinner and sort of rest on top of the spring. I fastened mine down with zip ties so they wouldn't move while I was installing the springs.
gta892000
Sep 16, 2015 12:37 AM
