cleaning the block
Old Oct 27, 2002 | 09:42 PM
jizzyz28's Avatar
cleaning the block
i am about to clean my engine block, i need to know if you guys have heard or know anything about cleaning with kerosene. i know you have too use 4 1/2 qts of 10w oil and 1/2qt of kerosene. I heard that transmission fluid works pretty good also any info would help.
Old Oct 27, 2002 | 11:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
huh? Kerosene, ATF and 10w are just different grades of oil. None are "cleaners". You need a solvent or degreaser to clean a block not oil.
You should just take it to a machine shop and have it hot tanked. If you want to degrease it, take it to a wand car wash and pressure wash it with engine degreaser. Dry it off with compressed air.
Old Oct 28, 2002 | 10:17 AM
Fast3rdGen's Avatar
i think he's talking about de-sludging the engine. yeah a half quart of kerosene is al that those fancy can's of "motor flush" are. be weary if the motor has high miles. i did this to my original 305 and it died 3 days later. i only ran it for half the recomended time which was 5 minutes. when i drained the oil it almost over flowed a 7qt drain pan. (only had 4.5qt of oil and .5qt kerosene put into it)
Old Oct 31, 2002 | 10:04 PM
laiky's Avatar
try atf first, it has detergents that will loosen sludge, not as well as kerosene i imagine.
one word of caution though, loosening sludge can result in clogged oil passages, it doesn't neccessaarily disolve, it may break off in to chunks or lumps. if your set on flushing it i would use a light oil afterwards and change it a few times before logging many miles
Old Nov 1, 2002 | 11:53 AM
aklaim's Avatar
This is in the WRONG forum. This should be moved to Tech/General Engine.
Old Nov 3, 2002 | 09:16 PM
jizzyz28's Avatar
i appreciate the help guys, and i know i misplaced the question i wasn't paying any attention when i put it on the site
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
IROCtometal
Sep 9, 2015 10:01 AM
gixxer92
Sep 1, 2015 04:32 PM
