new springs...
new springs...
If I get new springs, which are about 1 to 2 inches lower, will I need a camber kit or something? Or will the camber align itself once the springs settle?
Akshay
'89 camaro RS T-5
Akshay
'89 camaro RS T-5
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Camaros come stock with camber/caster adjustment plates. Although you cant adjust them a whole lot. They'll be enough to correct the camber/caster to a more streetable level. Me on the otehr hand use it for STUPID CAMBER as I call it haha. Your gonna need alignment after the springs. The shop will also correct your caster/camber at the same time as the alightment. I suggest though if you race and what not (turns that is not straight light) make your camber allitle more negative then the stock setting. I think like -.5-.75 is a good setting.
luvofjah
May 31, 2015 07:21 AM
luvofjah
Oct 4, 2010 07:09 PM
