how wide of tires can i get on stock rims?
Old Nov 3, 2002 | 10:14 AM
Guest
Guest
Posts: n/a
how wide of tires can i get on stock rims? i have the stock 15x7" rims on my 91 firebird. the stock tire size is P215/65R15 can i get some P265/60R15's? or will they not fit on my stock rims. also will i have a problem with the tires rubbing?
Old Nov 3, 2002 | 09:13 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i had 275/60's on the same rims they rubbed a little bit on the inside wheel well around really hard turns but nothin ya couldnt fix with a bfh... 265's would probably be alright though
Old Nov 3, 2002 | 09:39 PM
Guest
Guest
Posts: n/a
well i'm only going to put the 265's on the rear. i'm going to keep 215's on the front
Old Nov 4, 2002 | 11:19 AM
89RsPower!'s Avatar
i was refering to the rear....
Old Nov 4, 2002 | 12:00 PM
pianiy's Avatar
You may run into heat issues with tires that wide on a 7" wide rim. Being that 255 is really the widest you should go on an 8" rim I can only imagine how round your sidewalls look when they're mounted. When they roll, they'll flex even more and create alot of heat which could be very dangerous. I'd stay with something smaller or switch to a larger rim. Don't do dangerous things to get the look you want. :nono:
Old Nov 5, 2002 | 07:07 PM
82camaro's Avatar
Car: 82 camaro SC
245/60's are the largest I would go, and that's pushing it. You would probably get better performance with 235/60's. A tire that is too wide for the wheel hurts traction and looks kinda goofy(IMO)
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Randomtask2
Aug 13, 2015 01:57 AM
Exxon Limited
Aug 9, 2015 08:13 PM
