Anyone got any pics of the RoadTech coil over conversion installed?...
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I'm interested in picking up a set but I just wanna see how they look first installed.
Car: 1987 Pontiac TransAm GTA
Engine: Vortech S-Trim, 355cid
Axle/Gears: Mosier 12bolt, 3:73 Eaton locker
Re: Anyone got any pics of the RoadTech coil over conversion installed?...
Here's mine.
http://207.53.239.181/~terry/K-member.htm
The "installed" picture is at the very
bottom of the page.
Here's some from the bottom of the RatMobile
(BBC drag car)
http://207.53.239.181/~terry/RatMobi...f/IMG_0408.JPG
http://207.53.239.181/~terry/RatMobi...f/IMG_0409.JPG
These show the castor-camber plates
http://207.53.239.181/~terry/RatMobi...f/IMG_0412.JPG
http://207.53.239.181/~terry/RatMobi...f/IMG_0413.JPG
http://207.53.239.181/~terry/RatMobi...f/IMG_0415.JPG
hth,
T.
Originally posted by bjm323
Does RoadTech have a website? Where can you buy this setup? I'm interested in the Caster/Camber plates.
http://www.roadtechonline.com
hth,
T.
I am diehard for coilovers, but with third gen applications I have been told time and time again will not hold up in the long run without fabricated support to the upper strut mount area to support the weight of the vehicle. The stock design spring doesn't rest the weight of the car on the fender like the coilover setup requires.I've decided not to butcher the frontend to make this work- It'll cost to much time/money for the gains in my opinion.
Food for thought for everybody.
Also, I have already fabricated upper brackets supports that will mount in the rear shock area to dispurse the load back to the can area when I purchase and install my rear Koni coilvers. I have also welded braces to the lower axle shock mounts already for added strength.
Street Lethal
Aug 13, 2015 08:28 PM
