Proportioning Valve
Old Nov 16, 2002 | 03:15 PM
86TATpi's Avatar
Proportioning Valve
Just a couple questions, what does that nut with the rubber piece in it in the end do? And what is the difference between the valve for the all wheel disc and the rear drum brakes?
Mine is leaking from that little rubber piece in the front and I'm having a hard time finding a replacement because I have all wheel disc.
1986 Trans Am
Old Nov 16, 2002 | 06:09 PM
ede's Avatar
ede
not sure about the rubber piece. for 4x disc they use a flat sided machined alumninum PV the drum/disc cars used a round cast looking PV, sometime in the late 80s all cars used the machined looking one, that's what you need. gm parts ought to be able to hook you up with no problems, or any salvage yard.
Old Nov 16, 2002 | 11:50 PM
86TATpi's Avatar
Dealership doesn't carry it anymore which sucked, and there is a salvage yard Cambird which the name speaks for itself and they said they have some, but it's hard to find because they said I need the valve for rear disc and they have over 500 F-bodies to sort through. Hopefully I get one by Monday. I'm sick of seeing the car sit.
Old Nov 18, 2002 | 06:47 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
You will need GM part# 14089497
It still shows available;
14089497
VALVE ASM
$97.09 Retail
$67.97 Wholesale
$48.55 Dealer
If it were me, I'd buy a new one.
Thanx,ANDYZ28
Old Nov 21, 2002 | 02:34 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
I priced the combination valve at the dealer at 97.00. they told me they could order it.That is the only parts on my brakes that is not new. My brakes dont work.Theres no air in the lines. Ive replaced the booster mastercylinder front rotors pads calipers
rear calipers rotors brake cables rear pads and my car will stop
on a dollar.The peddle is firm but in a panic stop the brakes wont lock up and no one has any suggestions.
Old Nov 22, 2002 | 08:03 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Order a new valve from here;
http://www.gmpartsdirect.com/index.c...TOKEN=43475709
You may find their prices more reasonable.
Thanx,ANDYZ28
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
