pa front k member kit
Old Nov 18, 2002 | 03:56 PM
jimmbo's Avatar
does anyone know if the pa k member kit will work/fit ok with a bigblock chevy?
jimbo
Old Nov 18, 2002 | 08:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Why not? SBC and BBC use the same location for the engine mounts. There's nothing else engine related to the crossmember.
Old Nov 19, 2002 | 12:33 AM
RoadRacer's Avatar
I have the PA k-member with a BBC and it made the swap WAY easier. All the problems that others have mentioned with k-member intereference disappear completely.
Old Nov 19, 2002 | 12:27 PM
MdFormula350's Avatar
the price is not bad either, 400 bucks is the cheapest one that thunder racing caries..
Old Nov 20, 2002 | 02:09 PM
jimmbo's Avatar
thanks for the replys
just needed reassurance.
jimbo
Old Nov 20, 2002 | 02:58 PM
Slow91bird's Avatar
I hope this isn't off topic, but......
That light weight k member from Thunder Racing; think its worth the price and work to get the weight savings?
Old Nov 20, 2002 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That $400 one listed on Thunder Racing is just for the k member. It doesn't include motor mounts (front motor plate required). It doesn't include spring pirches (coil over kit required).
Saving weight depends on your needs. My car is still nose heavy. For me, spending that kind of money is worth it however I still haven't bought the front end kit. I still use the complete factory front end except for V6 front springs and Koni SPA1 struts.
Old Nov 22, 2002 | 02:54 PM
jimmbo's Avatar
one other thing for you guys considering this
the chromoly version is only three pounds lighter than the mild steel version (3lbs= $100 plus more in price)
just wanted to let you know..
just doesn't seem worth the extra c note.
jimbo
Old Nov 22, 2002 | 06:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I just need the money.
k-member $399 (I don't need the motor mounts or spring pirches
a-arms with adjustable rod ends $395
Coil over kit $289
Total cost for the kit, $1083 US. Current exchange rate = $1709 Canadian. Add on taxes, shipping and brokerage fees and I should be able to get everything in my hands for about $2000 Canadian. Just to shave about 100 pounds off the front of the car just isn't worth it. I can spend a little more than that for some nice aluminum heads and get better performance results.
As nice as it is and I'd like to have the kit some day, it's just not in my budget for a while.
Old Nov 23, 2002 | 04:10 PM
RoadRacer's Avatar
It's certainly not cheap! While $2k might seem steep for $100lbs, I found that the extra room it gained my with the big block installation is really what made it worth every penny!! Add to that the ability to use custom large-tube headers and it was a no-brainer.
Definately not for everyone, but the PA k-members ARE very nice pieces.
Old Nov 23, 2002 | 09:04 PM
AmorgetRS's Avatar
Does someone make one that is a 100% replacement?
Old Nov 24, 2002 | 09:33 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
PA Racing part # 1197 MMSP...stock a arms, springs, and motor mounts will bolt right up. BTW, this is mild steel, I don't think they make a chromemoly version.
I ordered mine from Thunderracing, should be here soon.
Old Dec 21, 2002 | 07:28 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
I keep looking at this setup and wondering if i should go for this set up or not....granted its A LOT of money but SOME things you just cant put a price on. This setup will take "shave" a few pounds off my car right? Are there any other advantages to this set up vs. stock k-member/stock lower control arms? Last..how STRONG is this set up vs. stock components? Ive heard the chromoly is prone to cracking/breaking...any truth to that? Basically my main question is are these setups just as strong as the stock setup??
Later..
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
Nov 16, 2015 01:13 PM
