Installing front struts/shocks
Old Nov 19, 2002 | 05:46 PM
MoJoeVanilla's Avatar
Is it worth saving the money and putting my KYB struts on myself...or should I have it done... is it really that hard? i know the rear ones arent to difficult...but not sure about the struts
if anyone has any suggestions....please help
Old Nov 19, 2002 | 06:48 PM
ede's Avatar
ede
only problem i've ever had or heard of with struts is getting the bolts out. they're splined under the head and rust in place pretty good. i put the nut back on to protect the end of the bolt and beat the hell out of it with a BFH and after it pops out a little use a punch to drive it on out. you may still trash the bolts so be prepared to buy new ones.
Old Nov 19, 2002 | 09:13 PM
MdFormula350's Avatar
well it all depends on how much you could get it done for...
but i rather do it myself and spend a day having fun
just make sure you properly support the car off the ground and use the jack to control the movement of the arm... dont wont to loose any springs
Old Nov 20, 2002 | 05:42 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Click the link in my sig, check it out and see if you're up to doing what I did...if so, do it yourself and save $$$$ for more mods!!
Ed
Old Nov 20, 2002 | 02:43 PM
Desert86Roc's Avatar
Definately change them yourself. However, do have the front end aligned afterward. The strut bolt holes at the bottom can allow quite a bit of movement, and having fresh struts will change the geometry.
Old Nov 20, 2002 | 08:00 PM
sllt1776's Avatar
Car: 89 Iroc-Z
yea do it yourself. you learn more that way. the 2 lower bolts are tough. i had to use my lug wrench t-bar to have enough leverage. other than that it was pretty easy. don't forget to chech the strut plate bearing for damage while you have the strut out and replace if necessary
Old Nov 20, 2002 | 08:44 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
hmmm would they be easy with an impact wrench
Old Nov 21, 2002 | 12:24 AM
thanks...i'll definitley be doing them myself...are KYB gas-a-just in the back and KYB GR-2's good in the front?? and where might be the best place to get these(cheapest place)
Old Nov 21, 2002 | 10:52 AM
sllt1776's Avatar
Car: 89 Iroc-Z
yea an impact wrench would be eaiser but i have no power tools
Old Nov 21, 2002 | 10:53 AM
sllt1776's Avatar
Car: 89 Iroc-Z
i bought mine online at the shockware house.
Old Nov 21, 2002 | 11:38 AM
aklaim's Avatar
Yearone.com A set of front gr2's and rear gas-a-just are about $135.00
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mustangman65_79
Aug 12, 2015 06:39 AM
