home made STB..
home made STB..
anyone made their own STB? i am thinking about building one with the tools in my auto tech class.. but im not sure what type of metal i should use and stuff. and if it would be worth it. anyone done it before. especialy on a TPI car?
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Here's one I made earlier.
You will need:
tubing-1" diameter
pipe bender
chop saw
mig welder
tubing notcher(homemade)
steel plate
2-pack volvo silver paint
You will need:
tubing-1" diameter
pipe bender
chop saw
mig welder
steel plate
Got me thinking... Is it possible to make one that doesnt go over the engine... engine will be sticking through the hood. Would connect to firewall or would this still be too much flex without a crossover? I work in a company that builds bent tubing for aircraft engines so have a lot at my disposal. Maybe weld a brace along the firewall and connect to that, maybe 1"-1.5" .065 wall stainless tubing. hmmm... got the wheels turning.
Car: '92 RS Camaro
Transmission: TH400
I've got some steel rod which I turned down on a lathe which fits into the STB exactly.through this are drilled holes big enough to insert the fixing bolts.I suppose you would call this a sleeve.
Car: '92 RS Camaro
Transmission: TH400
Mild steel my good man,no heat treatment.This is way,way strong enough when you look at the thickness of the steel left after the holes are drilled.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
