changing spindles to get abs
Old Nov 30, 2002 | 05:47 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hey Guys,
I have been doing alot of thinking. I really want abs. I was thinking if it would be possible to take the spindles from a car with abs, like a grand prix or some other car with abs that uses spindles simular to our's. I know you need the cv shafts in order to get the abs to work. Is there away you can think of to get around this?
I was also thinking you could take the rear spindle of a grand prix with abs and re machine it to fit an "A" arm.
What do you guys think?
Any ideas of your known?
thanks:hail: :hail: :hail:
Old Dec 1, 2002 | 04:45 PM
Marc 85Z28's Avatar
You may not even have to go that far. I know a lot of the older RWD Fords (early-mid 90's) and late model 2WD trucks use spindles and integral brake rotor/hubs just like our cars. Most of them have pressed on reluctor rings on the inside of the rotor. You could check a junkyard to see what would swap over. Just make a bracket for a sensor...
Old Dec 1, 2002 | 06:56 PM
Trux's Avatar
Transmission: t-56
=D
Thanks,
HAve not heard of spindles with abs, just spindles with an open wheel wearing.
Thanks:hail: :hail: :hail:
1992rs/ss
16
Jan 28, 2016 09:58 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
TheJoeY88
Aug 13, 2015 06:51 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
