Ronal Firehawk wheels with Eibach Sportline springs
Old Dec 13, 2002 | 07:32 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I'm giving serious consideration to getting the Ronal Firehawk wheels but I'm worried about the 9" wide wheel clearing with the 2" drop from the Eibach Sportline springs currently on my car. I'll be using 275/40ZR17 tires to keep the same diameter but the width will obviously be greater. Is anyone out there using a similar setup? I'm aware of cars with the ProKit springs having little to no problems but what about the Sportlines?
Attached Thumbnails Ronal Firehawk wheels with Eibach Sportline springs-mine.jpg
Old Dec 13, 2002 | 04:42 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
I'm running 275/40/17 all around with sportlines without any problems. Be sure to check your offsets and backspacing. You shouldn't have any problems unless you've got a couple hundred pounds of stereo equipment in the back.
Old Dec 13, 2002 | 04:47 PM
CrazyHawaiian's Avatar
Car: too many ...
I'm running 275/40/zr17's in the rear with Sportlines on my 91 z. No problems or rubbing at all. There is still some fender gap with the 40 series tire but not much. I will fix that soon
Old Dec 13, 2002 | 04:51 PM
Mongoose's Avatar
Car: 90 Formula
The rear isn't what I'm worried about,the front is. Will the 9" wide wheel and 274/40R17 clear? I'm aware of the supplied spacer so I really need to hear from someone with Ronals and Sportlines.
Old Dec 13, 2002 | 07:37 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Actually, the rim is not a 9, but a 9.5"
Old Dec 13, 2002 | 10:57 PM
Terry Kennedy's Avatar
Car: 88 IROC
Transmission: pg
Axle/Gears: 9" w/3.89
Mongoose,
Talk to jmatlock88 I know he has the wheel's and a set of Eibach springs but I'm not sure which one's. You can find him here or at
jmatlock88@aol.com
Old Dec 14, 2002 | 07:07 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I got the SLP Firehawk rims and Eibach Prokit - neither have been installed on my 83 TA yet other than a trial fit for the rims.
I know you're asking about the Sportlines; however, you might be intersted in the following:
1. I had to use a 5/16 spacer to get the front rims to clear the tie rod ends as well as the bearing dust caps.
2. The SLPs did not come with spacers. I think the Ronals come with 1/8 spacers but you may have to get 5/16 spacers anyway;
3. As you probably know, the Ronals have a white centre cap with their logo on it and a plain face cut unless you pay extra to have them painted. The SLPs have dark grey centre cap and face cut. The SLPs might look better your car because of the grey centre cap as per the photograph attached hereto.
Attached Thumbnails Ronal Firehawk wheels with Eibach Sportline springs-a020_xxa.jpg
Old Dec 14, 2002 | 08:51 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I have the SLP firehawk rims and 1 1/2 in lowering springs on my '82.. No trouble at all with fit here. My set came with lug nuts and the spacers but since I had no clearance trouble the spacers are collecting dust. I am pretty sure I didn't need spacers because of the Baer setup I have though.
You can see how it sits in this thread.
https://www.thirdgen.org/techbb2/sho...here+is+the+82
Old Dec 15, 2002 | 01:19 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I have the Eibach ProKit and the Ronal 17X9.5s with 275-40-zr17's. I had no clearance problems except for griding a little on my passenger tie rod end. I had to use the spacers and special lug nuts on the front. I think you would be fine with the Sportlines also. My buddy is running Sportlines with ROH ZS 17X9.5s with the same tire as I have... again, no clearance issues.
Old Dec 15, 2002 | 07:04 AM
Mongoose's Avatar
Car: 90 Formula
I was under mine yesterday changing the oil and took a good look at the tie rod ends and even with the 16" wheels they sit pretty close. I guess with the extra inch of diameter it should be OK. Maybe there were differences in front rotors from year to year?
Old Dec 15, 2002 | 01:22 PM
MdFormula350's Avatar
very nice looking car!!
i want to get those rims so bad..
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
86White_T/A305
Aug 17, 2015 12:16 AM
