Replacing Brake Lines
Old Dec 17, 2002 | 07:27 PM
J Kylez's Avatar
How involved is changing brake lines on a GTA with 4 wheel disc brakes?
Old Dec 17, 2002 | 10:11 PM
87daddyformula's Avatar
Car: Formula
Engine: 5.0L
Transmission: 700R-4
I am not an expert on the subject but I would think that you would just have to bend the lines yourself or get after market oem replacements...then again I could be wrong...I would get a few more opinions before you go riping out your brake lines. Just my opinion!
Old Dec 17, 2002 | 10:47 PM
jbcmyk's Avatar
brake lines
i'm far from an expert, and a 92 rs is no GTA, however i installed braided steel lines from summit and it was a piece of cake.
jb
Old Dec 18, 2002 | 02:36 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Remove debris from ends of lines, remove, cover up exposed areas with tape to avoid contamination if needed while they are off, put on new ones, bleed brakes, enjoy!
On a side note speed bleeders help bleed the brakes much quicker and while you are at it you might as well replace the pads if they aren't that new.
Old Dec 18, 2002 | 03:13 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You are talking about the flex lines, right?
Ed
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
