Rear lower control arms
Old Dec 18, 2002 | 01:28 AM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
Does anyone have a closeup picture or detailed description of how the stock rear lower control arms are installed. I'm removing the Lakewoods and I forgot how the original were mounted.
Old Dec 18, 2002 | 03:15 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
No pic handy, but the stockers go in so that they are an inverted "U", with the bend in the channel on the top...that's it.
Ed
Old Dec 18, 2002 | 09:21 AM
Holio's Avatar
Car: 84 Z28
Engine: 305 L69
Thanks Ed, I got that part, but I think there is a front or back to them. One end of the control arm ( at the top ) is smooth and the other end has a tooth looking pattern cut into the steel. Also, there is three bolt holes though the control arm, two holes have a bolt and one hole at one end of the arm doesn't (not sure of the purpose of all that). Also, not sure if the empty hole end of the arm goes to the front or the back of the car.
Gary
Old Dec 18, 2002 | 10:44 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
EDIT: I just re-read your message and don't have pics of the stock ones.
Here are a few pictures
Old Dec 18, 2002 | 09:14 PM
ebmiller88's Avatar
On the earlier LCAs, there was a brace bolted into them, hence you have the 2 bolts showing on your arms holding the brace in. Look in there and you should see it. These are stronger than the LCAs that don't have them. I'm pretty sure the empty hole goes toward the front. I don't think it will matter either way. It won't make that much of a difference.
Ed
1992rs/ss
Jan 31, 2025 05:10 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
