disc brake swap
Old Dec 20, 2002 | 01:13 PM
rsarol's Avatar
disc brake swap
I am doing a rear drum brake to disc brake swap. Does anyone know if I need to swap out the proportioning valve?
Old Dec 20, 2002 | 01:29 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Re: disc brake swap
Yes you will need the valve from a disc rear. other than that your all set.
HTH
By the way...Welcome to the boards! Lots of good info here, and alot of knowledgeable people too. THe best bet to save any problems is to read Brad's thread at the begining of the Appearance and Detailing forum. This will make everything move smoothly for you. Again welcome. And enjoy! Here is the link for you. It's just the rules of the board. https://www.thirdgen.org/techbb2/sho...hreadid=143760
Keiran
Old Dec 22, 2002 | 03:19 AM
MdFormula350's Avatar
to be on the safe side i would get the one for the disk brakes.
Old Dec 22, 2002 | 12:09 PM
Nasty_Bird_'90's Avatar
When I put my 9 bolt in the car, I used the stock PV from my 10 bolt drum rear and they work great.
Old Dec 22, 2002 | 01:04 PM
4L60bliss's Avatar
This isn't really a TPI question, but since I"m not a moderator, I don't really care..
Which disc brakes are you swapping too? I swapped to the early style cast iron brakes and I was rather dissapointed. I went from decent drum brakes w/ a functional parking brake, to a marginal set of discs w/ a non-funtioning parking brake. Not to mention, despite the lack of braking ablility from the rear, I now have to clean all four rims, instead of just the front I would say that unless your installing the newer aluminum PBR brakes, don't waste your time.
To answer your question though, use the disc brake prop valve.
Old Dec 23, 2002 | 08:16 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
First off, what the hell car is it on?? "Need the info..."
Year, make, model, stock setup?? Whatcha got? Can't read your mind...
This might help us to help you out.
Oh yeah..welcome aboard!!
Ed
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
