Powder coat from spohn
Old Dec 26, 2002 | 01:35 AM
big_ty2003's Avatar
is the $40 for powder coating the SFC really worth it?
Old Dec 26, 2002 | 01:48 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
That is really going to be a personal preference. If you are asking if he produces a quality powdercoat then the answer is yes. It is a very high quality finish.
On the SFC's you will need to grind away the powder coat at the points where you will weld.
I ordered mine with the powder coat. It looks good and will protect the SFC's. After they were welded up I touched up the paint with some spray.
-Schultzy
Old Dec 26, 2002 | 02:16 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
My next set of SFCs will definitely be Spohn. However, I will not pay extra for powdercoating that I will have to grind off, weld on, and recoat to keep from rusting. I would buy them bare finish, install them, and then cover them with POR-15. That will keep them from rusting for a long time.
Just my opinion.
Ed
Old Dec 26, 2002 | 03:04 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
My problem would be, can you expect to be able to coat the top of the SFC that's snug against the underside of the car?
That's the reason I could get them coated...
Other ideas?
Old Dec 26, 2002 | 03:57 AM
ebmiller88's Avatar
Let me add a bit to what I said earlier....I plan on test fitting the SFCs under the car by jacking them up snug against the car and marking them where they will be welded. I will then coat them with POR everywhere except where they are marked so the tops and other unreachable places will be covered. Then I'll weld them in and coat the welds with POR. I think this will do. This way the coating will be uninterrupted. I know they're under the car but I don't want them to look like ***.
Ed
Old Dec 26, 2002 | 05:15 AM
waltersb's Avatar
This would be a good time to coat the underside of the car where they will be too.
I'm debating the powder coating issue too.
Old Dec 26, 2002 | 01:55 PM
MdFormula350's Avatar
i might as well get the black ones.. either bare or black the new spohn sfc's would be a great choice it seems..
Old Dec 26, 2002 | 06:19 PM
Car: 1989 GTA
See, like I said personal preference. The pics above are before the touch up paint and acutally the rubber skirting on my GFX covers the welds so that you don't even see that part. The parts that are visible under the car look great. You only have to grind away small amounts of the coating where you will weld. That is where my respect for his powder coating came from ;-) It is a pretty thick coating.
Which ever way you plan to go you will love what the SFC's do for your ride.
Good Luck.
-Schultzy
Old Dec 26, 2002 | 09:32 PM
Z28DJP1987's Avatar
What you would spend on the POR-15 and the labor to paint that
area with it, Iwould go with the powdercoat. I got mine coated and $3 can of spray paint. My opinion.
Old Dec 26, 2002 | 11:06 PM
ebmiller88's Avatar
I hear ya. The POR "starter kit" which has enough to do the SFCs and then some is only $15 at the website...well worth it IMO for the protection it gives.
Ed
Old Dec 27, 2002 | 07:21 AM
Z28DJP1987's Avatar
Try $15 +$6 shipping and that = Half the cost of the
Powder coating. Then you have the three step process for the POR-15, thats going to be close for a complete job with the starter kit.
Old Dec 27, 2002 | 09:14 AM
waltersb's Avatar
How seemless is it to join to coats, say you grind off the powder coating and then POR-15 the welded bits...
Or get them bare, POR-15 the parts that you know aren't gonna be welded and then go over the unwelded bits with POR-15 and sorta merge the 2 coats?
Old Dec 27, 2002 | 09:17 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
when i did mine, i got the SFC's powder coated, then primed and painted the welds it looks great and is very seamless.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
cmichael
Exterior Parts for Sale
Dec 21, 2015 06:56 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
darwinprice
17
Oct 11, 2015 11:51 PM
