Do the springs in your lowered car rattle?
Old Dec 26, 2002 | 09:45 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have the Eibach Sportlines for a little under a year now and ever since I got them the rear springs rattle so bad. It is so annoying and it sounds like the car is falling apart. I know that they were installed correctly because I took them to an extremely reputable wheel shop. They tell me that all Camaro's rattle when lowered and that there isn't anything I can do. Can I put some pieces of hose or something over the first coil so that it doesn't move in the housing?
Old Dec 26, 2002 | 11:07 AM
MdFormula350's Avatar
so the stock factory rubber insulators are in? if not i would use some hose that should work. thats what some have done with like 1.75 inch drops..
Old Dec 26, 2002 | 12:20 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I have the sportlines in mine Shifty. Been in for about 1.5 years - no probs. I did replace the isolators when I put the springs in.
-Schultzy
Old Dec 26, 2002 | 02:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
What exactly are the isolators? Is there a part number for new ones/performance ones or is it just a rigged thing with hose pieces? Any pics?
Old Dec 26, 2002 | 05:58 PM
CrazyHawaiian's Avatar
Car: too many ...
Its like a rubber doughnut that mounts between the top of the spring and the body. I think you can buy poly ones.
Old Dec 26, 2002 | 06:25 PM
Car: 1989 GTA
Not sure about the poly ones but you can order factory rubber ones from GM. IIRC they were only like $5 each.
-Schultzy
Azrael91966669
25
Jun 20, 2017 04:04 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
novaderrik
Aug 10, 2015 12:44 PM
mustangman65_79
Aug 8, 2015 12:07 PM
