Front coil-overs
Old Dec 26, 2002 | 07:29 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Front coil-overs
I was wondering if someone could give me some input on them.
My question(s) are if they really made a difference in the quarter mile area besides the weight reduction? Because I can get a setup real cheap off of a friend of mine who is goin to an all out race suspension.
Old Dec 26, 2002 | 11:17 PM
AFreaknGoodTme's Avatar
I've checked into this extensively. My opinion is that if it is a roadrace or a fulltime street car, I would not recommend the front coilovers unless you weld up mor suport to the upper strut mount area of the inner fender. It is not designed to hold the cars cornering force AND the weight of the vehicle. The can area where the front upper springs rest stock are what hold up the car, not the strut mount like coilovers will result. They will fail over time if not futher supported.
Old Dec 27, 2002 | 10:33 AM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Thanks for the input AFGT but this will be pretty much a strip only car. I really want to know if they are better or just as good as the moroso trick springs with 90/10's.......My buddy says they are but I just wanted some views from people who run this type of setup....More then likely I'll go with this setup cause i like the idea of the weight loss but if someone could give me some insight it would be very appreciated thanks again........
Old Dec 27, 2002 | 10:56 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Front coil-overs
What setup? I'm sure there are a couple of manufactures who sell kits for a third gen. You need a kit that puts a spring over the front strut so you still need the 90/10 struts. www.paracing.net sells a kit.
A generic coilover shock system needs a framework fabricated for somewhere to support the car from.
As mentioned above the inner fender where the top of the strut mounts will need to carry the weight of the car. A strip only car will be fine but I also wouldn't reccomend it for street use unless the inner fender is reinforced.
Old Dec 27, 2002 | 12:28 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Re: Re: Front coil-overs
It is the art morrison setup and there he already has the lakewood 90/10's in it already so that is a plus but he didn't say anything about reinforcing the strut mounts but I'll check into that....Stephen do you run this setup? And if you do does it lift the front like the trick springs?Thanks
Old Dec 27, 2002 | 02:45 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
So do you consider welding up the strut mount area at the seams and what not would be good enough? Cause I was considering doing the coil over conversion yet I drift and take turns hard. What means of reinforcement do you think I should do? Thanks.
Old Dec 27, 2002 | 08:31 PM
german-motorsport's Avatar
1QWIKZ you got mail!
Stuff Made us laugh, well intense research is: owning it, working with it or trying it!
Project X1 is on the road/Strip for 5 Years no cracks or welding spots that poped!(1150KG!)
below some points to get the front stiffer and reduce(ad some) weight!
Coilover
Wonderbar
Strut tower brace
light alu rims
gfx hood
aluheads
12 point gage
no power strg ..........
if you really dig fbody suspension parts there is a Car craft issue
from the early 90´where all the problems are discussed and partnumbers and producers are named!
Yes way back then, 1LE was already a topic!
Gone does not mean forgotten, as some thing they invented the 1LE stuff in here!
In our eyes the real bible for fbody owners!
WWW.CAMARO-FIREBIRD.DE
Old Dec 27, 2002 | 08:47 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Coilover
Wonderbar
Strut tower brace
light alu rims
gfx hood
aluheads
12 point gage
Um German? I don't know what made you laugh but the question that I'm trying to get answered is very easy.....IS this the ideal suspension for DRAG RACING!!!!
Old Dec 27, 2002 | 09:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
That's a picture of a good front coil over system for a third gen.
My front suspension is roughly still stock. I use Koni SPA1 struts and V6 springs. Other than that, everything is stock.
Old Dec 27, 2002 | 09:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
A strut tower brace would probably be a good idea. It will help transfer the forces to other parts of the body.
Old Dec 27, 2002 | 10:53 PM
I'm taking this as an implication that my research doesn't mean squat because I don't own the setup and I don't know what I am talking about. I happen to see alterations in the stock can area via fabricated plate and welds to back my theory. Your car is not stock in support and your picture proves it. Sorry to humour you. I'd like to see a picture of the top side?
Old Dec 27, 2002 | 11:14 PM
JERRYWHO's Avatar
I have the same Art Morrison kit on my car and the plate is not welded in it bolts in with the factory bolts on top of the body and under the strut mounts.
Jerry
Old Dec 27, 2002 | 11:18 PM
Jerry
I am refering to his stock can area, not the upper strut mount plate. His is modified- Yours is not.
Old Dec 27, 2002 | 11:46 PM
This is a friendly word of caution, I'm not trying to ridicule your work.
Old Dec 28, 2002 | 12:02 AM
JERRYWHO's Avatar
Do you know anyone who has broken the body in the strut mount area with a coilover kit and how about some pointers on how it did so i can watch for it.
Jerry
Old Dec 28, 2002 | 12:05 AM
JERRYWHO's Avatar
Wow that was fast
Jerry
Old Dec 28, 2002 | 04:31 AM
I could think of better stuff, but at the time the PA coilover is the drag kit you need and want!
But check the rules in your class first ...........!!!!!!!!!!!!!!
No flame here to nobody...lol!
I guess its rthe old Question : does it make sense to ad a better sway bar?
Yes , but its even better to ad all the rest of the stuff and it would be more fun!
Walking with technology is even better, think about the world top vette shocks with this great metal formula in the shocks and adjust from inside..???? That would be grat to have now.......i guess it will take 1-2 years before we get this in the aftermarket....!!!
FOLKS ENJOY THE SEASON AND WE ARE WISHING ALL A HAPPY NEW YEAR!!!!!
AND YES FU::: SADAMMMMMMMM
Old Dec 28, 2002 | 07:36 AM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Jerry
Jerry, do you race your car 1/4 mile if so did this help improve your 60' times dramatically or what? Thanks
Old Dec 28, 2002 | 11:37 AM
JERRYWHO's Avatar
1QWIKZ:
I first had the Ei-bach drag spring kit with an air bag on the car and it was O.K. for street use (1.84 60ft with a 12.48 at pomona). With the weight reduction I have done, the front end (200 lbs ) ride height started to get too high, and with no way to change it short of cutting the springs, that is the reason I got the A.M. kit.
The A.M. coilover kit has a stiffer spring rate than the Ei-bach drag springs, so the street handling is better with the coilover kit. The next trip to the track I also installed a Dana 44 with 3.73 gears ( had 3.23 in the 10 bolt) at the same time. Now it runs 1.70 60 ft with a 12.52 at Fontana. This was all done with a stock 105k old long block, trans, torque arm, rear control arms and a 2400 stall 12 inch converter.
If your car is for everyday use and long trips than you have to plan your mods for that. My car is more of a street race car so I will be the test car for strut tower breakage on the street.
Jerry
Old Dec 28, 2002 | 11:42 AM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
1QWIKZ:
Jerry
Thank you very much for replying! My car is also more of strip car but it will be driven on the street here and there....So it sounds like it works so I will go ahead and purchase it from him....Also how long have you been running on the street with this setup? Curious?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
