1le rear brake question
Old Dec 26, 2002 | 08:03 PM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
Hi,
Pretty much have my 1le rear brake upgrade almost done. This board has been a huge help. I do have one question about the emergency brake though.
I ran the cables back to the stock location but they go past the piece in the tunnel that they are supposed to connect to. Even if I put the piece to its limit the cables are still too long by 3-4 inches. Any advice?
Old Dec 26, 2002 | 11:39 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
What year is the car? What year is the doner axle/brakes from?
I might be able to help you.
Thanx,andyZ28
Old Dec 27, 2002 | 12:00 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Is the brake upgrade on your '87 or the '92? Does your e-brake adjuster look like this??
Old Dec 27, 2002 | 08:49 AM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
car is an 87 brakes are from a 92!
Old Dec 27, 2002 | 08:52 AM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
axle is 9 bolt borg warner. i swapped on new backing plates for the brakes to fit, so only the brakes and backing plates are donor equipment.
-scott-
Old Dec 27, 2002 | 10:11 AM
ANDYZ28's Avatar
Car: 1982 Z-28
You have the wrong parking brake cables. You will need the ones for an '89 with J65.
Thanx,andyZ28
Old Dec 27, 2002 | 10:32 AM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
Andy,
Is there a P/N on these? Will the work with the existing equalizer? I may be stupid here but I pulled the brakes with e-brake cables off of the 92 z28 1le. what is the difference in the cables? do i have to have J65 specific to 1989?
Will one from 91 work? I found the P/N for 91 E-brake cable with J65.
Does the equalizer need to be replaced as well?
Sorry for the confusion in questions just wanna make sure i get the right parts
Old Dec 27, 2002 | 10:52 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i too did the pbr swap on my 88'. if you want you can go to orieleys and get the e-brake cables from them. they were the wagner brand and have worked ok for me. if you want oem then might try a search or someone can post part #'s for you.
Old Dec 27, 2002 | 09:29 PM
ANDYZ28's Avatar
Car: 1982 Z-28
I believe you will need 2 of part# 18033788. The parking brake cable saga is a long story. So I won't tell it now. But I believe these are the cables you need.
Thanx, andyZ28
Old Dec 27, 2002 | 09:31 PM
zimmstoy's Avatar
Car: 85 Iroc
Engine: 305 LB9
thanks andy..
the other issue i ran into was at the proportioning valve and getting the lines to screw in.. No go.. Are these differerent as well.. I was searching around.
The valve and MC i got is from a 92. Are they m1.5 as opposed to M1.0 threads which I think are on my car?
Old Dec 27, 2002 | 10:03 PM
Z28DJP1987's Avatar
Your brake lines on the 87 are SAE and the 92 are metric.
Old Dec 28, 2002 | 12:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Umm.. I thought they were all metric after 1984.
Old Dec 28, 2002 | 02:37 PM
Z28DJP1987's Avatar
Not when I installed a 1989 9-bolt in my 1987 IROC. The lines are different.
Old Dec 28, 2002 | 04:06 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Originally posted by zimmstoy
thanks andy..
You will need the proprotining valve from an early '89 J-65 car. If you get a new one ( highly recommended) from GM your lines should fit.
Thanx,andyZ28
Old Dec 28, 2002 | 04:07 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Yep, '84 and later all have the ISO metric "bubble flare".
Old Dec 31, 2002 | 10:14 AM
ebmiller88's Avatar
Zimms, you will need to install prop valve # 14089496 since you have an '87 car. AndyZ28 has more info and so does Daniel Burke.
Look here:
http://www.ws6transam.org/1LEbrake.html#1LEfront
HTH..Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
