front sway bar
Old Dec 27, 2002 | 09:30 AM
cerice's Avatar
front sway bar
Have a question about the front sway bar. How important is it to run the car with the front sway bar? Without using the front sway bar do you run into major handling problems, or is there no difference with or without the sway bar? Currently, rebuilding an 87 Z28 the guy helping me with the rebuild drag races mustangs for the renegade NMRA series. He believes i do not need the front sway bar, but he is mainly thinking from a racing view. This car will go to the track to get the best E.T. However, the car will mainly be driven around town. I will on occasion drive the car hard to have some fun. Just want to see what other people think about using or not using the front sway bar.
Thanks,
Chad
Old Dec 27, 2002 | 09:33 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
for street driving, i would say run with the sway bar on. you handleing will suffer from taking it off.
if you are just going down the 1320, and then turning around, you could leave it off.
Old Dec 27, 2002 | 09:34 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
If you are street driving it "I" would run a sway bar without one handling will be affected.... just undo the endlinks at the 1/4 track
Old Dec 27, 2002 | 05:32 PM
bob8748's Avatar
Keep the sway bar for the street... will make for a "wishy-washy" ride, just remove drivers side end link at the track and replace for ride home.
Old Dec 28, 2002 | 03:15 PM
MdFormula350's Avatar
i havent tried taking the endlinks off when racing at the track maybe i sohuld next time.. see if it helps me.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
