worn out front end parts
Old Jan 2, 2003 | 02:39 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
on my 92 rs, i took it in for an alignment, and they said that the idler arm has play in it and the tie rod ends are bad and the sleeves are rusted
does someone make replacements for these that are better than gm's parts-performance or drivability wise?
also is there any other parts that i should replace while im in there?
thanks for the help
mike
Old Jan 2, 2003 | 02:43 PM
aklaim's Avatar
Click here.....
This should take care of your front end.
Old Jan 2, 2003 | 06:07 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Moog parts are the only way to go on a rebuild. They are far better peices than anything else you can find, a little more costly but well worth it it the long run.
Old Jan 6, 2003 | 04:56 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Yeah I was looking at that front end kit. It seems to be a good deal. Is spohn good with delivery though How reliable are they? I think I may go with that. You guys have good luck with it?
Old Jan 6, 2003 | 05:11 PM
ctandc's Avatar
Actually.......if you want Moog parts, it's cheaper to buy 'em from www.rockauto.com
The kit from Spohn is $342 BEFORE shipping.
ALL the same parts, MOOG brand, from RockAuto is $310.93 SHIPPED.
Hey, it's only $40, but $$$ is $$$
HTH
Old Jan 7, 2003 | 04:48 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
I checked out that link. But do they have a whole kit like the Spohn? Or would you have to order each part individual? I didn't see any kit listed or maybe I missed it? I am up for saving $40.
Old Jan 7, 2003 | 04:51 PM
aklaim's Avatar
There is no kit. You just have to piece it all together yourself.
Old Jan 7, 2003 | 08:15 PM
ctandc's Avatar
You have to order each piece...
Simply click on your car make, model etc, then pick parts. The majority of all the parts you need are listed under STEERING....check suspension for the balljoints.
You need the following for a complete rebuild -
- Idler Arm
- (2) Lower ball joints
- (2) outer tie rod ends
- (2) inner tie rod ends
- Centerlink
- (2) tie rod adjusting sleeves
HTH
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
bellez77
Sep 5, 2015 08:39 PM
1nastygta
Aug 8, 2015 07:38 PM
