Replacing Rear Lower Control Arms....Easy Right?
Old Jan 4, 2003 | 11:02 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
These puppies are an easy swap right? Atleast I think so....I am going to be swapping my in the next week or two and want to hear if there is anything i shoudl be concerned about when doing them (ie only do one side at a time etc)
Old Jan 4, 2003 | 11:30 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Hey Dave. The only real thing I think will cause a problem is rusty bolts. Give them a really good lubing and leave them sit for a 1/2 hour or so before wrenching on them. Are you replacing the whole arm, or just the bushings? If doing the arms just lube the bolts and do like you said one side at a time. Should be fairly easy, but these are cars after all so expect the unexpected.
Keiran
Old Jan 4, 2003 | 11:59 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Keiran
Thanks man....that's sort of what i thought, I just wanted some re-assurance from others who may have done them in the past. I am replacing the arms and bushings, so I figure that is probably a lot easier than just the bushings since they are pressed in to the stock arms. I am not too concerned about the bolts since I will probably hit them with some Pen oil about a day before I do it and I will be doing it at my buddies shop so I will have access to Air tools and a torch if needed!
Thanks,
Dave
Old Jan 4, 2003 | 12:56 PM
vjo90RS8's Avatar
Car: 2002 Z28
They are a very, very easy swap, just make sure you do one at a time, (dont remove both control arms because your rear end may rotate, making an easy job harder).
Old Jan 5, 2003 | 03:11 AM
uk89camaro's Avatar
Must be one the easiest, and visually satisfying. (if you're putting on nice nright red ones!)
here's mine
Old Jan 5, 2003 | 08:57 AM
MdFormula350's Avatar
took me about 1/2 hour..
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
