spring and shock install question?
Old Jan 14, 2003 | 10:43 AM
mess21's Avatar
i ordered eibach sportlins blistens sp shocks and struts and spohn's LCA relocation brackets. i would do the install my self but the LCA relocation brackets need to be welded into place and plain and simple i don't weld. so any input on how much a shop would cost to install all of these parts???
Old Jan 14, 2003 | 12:21 PM
jos4570's Avatar
I would try to install the springs and shocks yourself. A shop would probably soak you pretty good on those two. I was quoted $400 at my local GM dealership, so I decided to do it myself. The welding for the relocation brackets shouldn't be more than an hour worth of labor. Probably $40-60. The bottom line is I would try to do the most work you can yourself and save yourself quite a bit of money. The shocks and rear springs are very simple. The front springs are a little more difficult but shouldn't be a problem.
Old Jan 14, 2003 | 01:24 PM
mess21's Avatar
sounds like a good idea espically if its gonna cost me $400 to have them installed!!
Old Jan 14, 2003 | 08:56 PM
MdFormula350's Avatar
take your time and get as far as you can..
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
redmaroz
Aug 16, 2015 11:40 PM
