Where do I get a steering box rebuild kit?
Old Jan 14, 2003 | 08:43 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
My steering box leaks from the pitman arm seal. I am going to rebuild it totally. I would like to know if someone sells a full rebuild kit for it? It is a quick ratio box. I want to replace seals, bearings, sleeves, and what ever else is replaceable. I'd hate to spend the 300 for an AGR box.
Any help will be appreciated. Thanx
Old Jan 15, 2003 | 08:11 AM
ede's Avatar
ede
not sure but i'd check gm parts first and if they didn't have it a shop that specializes in steering and suspension parts.
Old Jan 15, 2003 | 08:47 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I got one from NAPA to replace the rear seal in the steering box where the shaft goes in. Mine was leaking pretty badly. I dont remeber what all seals it came with, but im pretty sure it had the bottom one for the pitman arm shaft.
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
italiano67
Dec 11, 2016 09:21 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
