Why do I have to push the brake pedal so far before it will stop?
Old Jan 24, 2003 | 09:04 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I have put new shoes in the rear, and the pads on the front are fine. I've replaced both front brake lines and have put on a new master cylinder a couple years ago. I'm already thinking about when I get the car back out of storage in March, and I want to fix the brakes when I get it out. I have to push the pedal almost to the floor before the brakes really start to grab, but the car has no problem stopping. I can stop really fast, I just have to push the pedal a long way, and it just doesn't feel right. I've checked several times and the lines are well bled. I'm thinking on having the rotors turned and getting new calipers. Auto Zone sells remans for $10.00. I figure maybe the rotors have a little runout or the pistons are sticking in the calipers. Does it sound like I'm on the right track, or am I missing something obvious?
Thanks,
Eric
Old Jan 24, 2003 | 09:15 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
fluid level ok?
Old Jan 25, 2003 | 12:39 AM
jeffs82z28's Avatar
Assuming that your lines and master cylinder are "well bled",
I would check the adjustment of the rear brakes.
Old Jan 25, 2003 | 09:54 AM
MdFormula350's Avatar
when the last time you changed the brake hoses?
Old Jan 25, 2003 | 10:25 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I changed the brake hoses about a year and a half ago. The fluid level is fine and they are bled. I'm liking the idea about adjusting the rear brakes. I've checked it before, but maybe I'm doing it incorrectly. What is the proper way to adjust the rear drum brakes?
Old Jan 25, 2003 | 10:40 AM
https://www.thirdgen.org/techbb2/sho...ust+rear+drums
Old Jan 25, 2003 | 11:19 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Old Jan 25, 2003 | 03:33 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i just re did the brakes on my 89 iroc and the pedal was allways low since i bought the car, i redid the rear brakes. and set the a lil high, and they work great. and the pedal is alot higher but not perfect
1992 Trans Am
May 10, 2023 07:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
