Went to the track... need help!
Old Jan 25, 2003 | 04:46 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Long story short - 60' is a 2.621 That's with a 3.42 open and 255/50/16 Eagle ZRs back there. I know an SLP posi will help, but what can I do to get this thing to hook up harder? Laugh at the V6 all you want, but it'll fry 1st and 2nd gear right now. I want it to hook up better, short of slicks.... any ideas?
Old Jan 25, 2003 | 06:18 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Go around the water as much as possible. Do a short, "dry hop" once you are in the burnout area where all the hot, sticky rubber has been laid down by previous cars. DO NOT let the tire pressure down, this will make your bite worse with the street tires. If anything, put some wieght in the rear hatch well area.
Feather the clutch, lower your clutch dump speed. This will take some experimenting. Also, if the track temp is cold it won't help either.
These things work for me, then again, borrow some stickies from someone too!
Eric
Old Jan 26, 2003 | 02:14 PM
MdFormula350's Avatar
maybe rear lower control arms.. they should help you hook up a bit more.
UltRoadWarrior9
Jun 6, 2015 06:41 PM
Eric0840
Aug 30, 2013 06:32 AM
ATCFLYBOY02
South East Region
Dec 3, 2012 08:50 PM
BADNBLK
May 4, 2007 10:34 PM
87ROCZ
Sep 28, 2004 12:40 PM
