1LE Spring PART NUMBERS
Old Feb 1, 2003 | 12:09 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
im diving in to the start of another total suspesion upgrade but i need the part numbers for the 1LE springs (or ws6 springs for that matter) that would fit on my 91 Z28 all the way around. then it would be complete!!! :lala:
Old Feb 1, 2003 | 08:01 AM
Eightyninef's Avatar
no such thing. they were the same as any other WS6 spring, or IROC.
rears are long discontinued, fronts are still avail.
Old Feb 1, 2003 | 02:03 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
This is from www.1le.net
Front coil spring (code CDB): 14029396
Rear coil spring (code NNL): 10018091
Old Feb 3, 2003 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've been trying to replace my IROC springs (85). The Federal-Mogual web site lists the fronts as part # 5662. The rears seem to be the problem. They're listed as part # 5665 EXC Z28 (82-86. Summit says 82-91, I believe). The variable springs are CC635.
Any help would be appreciated.
JamesC
Old Feb 3, 2003 | 07:32 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
James, I believe you have my CD. If so, then there is a spring rate chart listing all of the part#s. One part# covers the top three front spring rates.
Thanx,andyZ28
Old Feb 3, 2003 | 08:13 AM
JamesC's Avatar
Hey, Andy,
I'll check out your CD. By the way (this is a bit off topic, sorry), I'm beginning modification to my spindles for the 1LE upgrade. Where the tapping is concerned, should I simply use a tapered tap of the size you recommend? Also, any news about the rear brakes?
JamesC
Old Feb 3, 2003 | 08:32 AM
ANDYZ28's Avatar
Car: 1982 Z-28
A tapered tap will work just fine.
News concerning the Rear Brake Upgrade "RBU" will be posted soon.
Thanx,andyZ28
Old Feb 3, 2003 | 08:57 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
do you all think that 1992 z28 springs will fit my 1991 z28? i hope so cause i have the part numbers for those and i konw i can get them at autozone. but i know they upgraded a little bit for 1992
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
