brake trouble...options
Old Feb 2, 2003 | 08:56 PM
86IROC350NY's Avatar
Hey,
I was wondering. i got a real spongy pedal, and I noticed I have been leaking fluid (know because the fluid gets low). OK, Now I know that the bleed valve broke off when i was changing my pads in the rear (yes an 86 with a disc rear...beats me too). Maybe that's where the leak is from.
What i want to do is get:
Wildwood front brake kit, pg 152-n in jegs.
Wildwood calipers for the back.
Or should i just change my calipers?
Or should i have the master cylinder/diaphragm checked out. i already changed the ckeck valve and the one that goes between the PCV and vac line. So it wasn't that.
I was told to get new calipers. The wildwood 2 piston design.
--Dan
Old Feb 2, 2003 | 09:04 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
I would just repair what you have, why spend money on race brakes if you drive on the street?
My 84 came with rear discs also and after installing new calipers, lines, booster, master cylinder, front rotors and pads, it stops great. My car sat for a long time so it needed more work than usual...again I would just fix what you have, you can buy new bleed screws.
Old Feb 3, 2003 | 01:27 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Just so you know, that Wilwood kit is designed to be a "drag race only" brake package. It's not designed for street use.
I'd fix what you have.
Old Feb 3, 2003 | 06:30 AM
Wildwood kits for the street
this is the wildwood kit for the street. Their front kits are for the street, and can be used on the strip. The Title says Disc brake kits for the street and strip.
maybe I'll jsut get new calipers, and master cylinder though.
--Dan
Old Feb 3, 2003 | 11:58 AM
Morley's Avatar
Re: Wildwood kits for the street
--Dan
Those GM rear calipers are NOT cheap, not by a long shot. Last time I checked (12 years ago) the fronts were around $22, and the rears were $150.
just get the bleeder out and getthe Recall rebuild kit, you should be golden after that.
Old Feb 3, 2003 | 01:12 PM
Car: Yes...
Re: Re: Wildwood kits for the street
AutoZone carries remanufactured GM calipers and they're pretty cheap. I just picked up a of front PBR's for $34 each plus core charges.
Originally posted by 86IROC350NY this is the wildwood kit for the street. Their front kits are for the street, and can be used on the strip. The Title says Disc brake kits for the street and strip.
--Dan[/B]
Well, Summit may advertise it as a "Street/Strip" kit (mainly because they also include 1st and 2nd gens. on that list.), but I've talked with Wilwood regarding a 3rd gen. heavy duty/street brake kit that could be used for heavy street driving and occasional auto-x and they DID NOT recommend their kit for that type of use.
Wilwood does make a nice heavy duty/road race type kit for the 4th gens., but has never made a similar kit for the 3rd gens. You could piece together a Wilwood kit, but be prepared to spend some big $$$. They won't break up any of their kits, so basically to get the various components you'd want, you have to buy different complete kits.
Check this thread from one of my fellow SC3G club members: https://www.thirdgen.org/techbb2/sho...hreadid=154139
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
