SFC's using angle-iron
Old Feb 2, 2003 | 11:03 PM
F-BOMB's Avatar
Anyone make sfc using angle iron instead, of tubing or square strock, whats anyones thoughts.
Old Feb 2, 2003 | 11:06 PM
pskel350's Avatar
i dont think it would be as strong...it wouldnt cost that much more to buy tubing.
hope this helps
Old Feb 2, 2003 | 11:09 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
rollcage spec chromoly tubing is gonna be the way to go, angle iron flexes too much unless your gonna weld two peices together and box them...
Old Feb 2, 2003 | 11:25 PM
F-BOMB's Avatar
Ya I hear you, I know tubing or square stock is stronger but I have angle iron laying around and was just wondering if any one has used it. I'm sure I'll make them out of square stock as it is strong and will have many jacking positions. Does anyone know the effects of welding in the sfc with no load on the suspension. I ask because all drive train and interior is out and this would be a very easy time to weld them in. IMO I don't think it sould matter because the suspension takes the weight of the drive train not the body.
Old Feb 3, 2003 | 01:18 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
As I understand it, it's best to have the "full" weight of the car on the suspension when installing SFC's. The body does get affected by the drive train.
Also, if you have the body propped up and it's not "true" when you weld in the SFC's, it will stay that way.
Old Feb 3, 2003 | 05:47 AM
ede's Avatar
ede
you can buy the square or rectangle steel for less than 20 dollars, most likely you'll pay more to get it cut than it'll cost.
Old Feb 3, 2003 | 07:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
To get the same strength out of angle iron as you can get from tubing, it has to weigh about 3 times as much...
Just do it right, some things are done the way they are for a reason, and need no further experimentation in cost reduction methods. I'm sure that if angle iron would work, somebody would be marketing a set of SFCs for $5 less than everybody else's, made out of it.
Old Feb 3, 2003 | 02:40 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
If everything is out of your car and is immobile, what is wrong with getting the square tube ,cutting it to size with the right configuration and resting the car with its weight on the sfcs. Then do your welding.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
BadSS
Aftermarket Product Review
Apr 28, 2001 05:02 AM
