Need advice on changing lower ball joints....
Old Feb 8, 2003 | 12:18 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
A few months back I had a run in with a curb because of some jerk with road rage and my alignment has been messed up ever since then. I decided that since my tie rods needed replaced I'd go ahead and change those and then go get it aligned. I changed the inner and outer tie rods and then took it to get it aligned. When I did, they told me they couldn't align it and showed me that my centerlink bushing were shot. So last weekend I got out and changed my centerlink. I now have a new centerlink, tie rods tha are only months old, and an idler arm that's less than a year old. So I took the car back to get the alignment done and now they showed me my lower ball joints. Both lower ball joints are literally only held in by the grease fittings. My question is .... how much of a pain is it to change the ball joints and is this even something I can do myself??? I've heard that they have to be pressed in or something .... is there any truth to that?? Any help would be greatly appreciated.
Old Feb 8, 2003 | 03:51 PM
ede's Avatar
ede
the greese fitting has nothing to do with ball joint retention. they're pressed, i think it's a pretty easy job. you'll need a press, should be able to get one from auto zone.
Old Feb 8, 2003 | 08:58 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
no press required.
www.fl-thirdgen.org/balljointreplacement.html
Old Feb 9, 2003 | 01:27 AM
HurtHorseZ28's Avatar
Originally posted by mrr23
no press required.
SWEET! I am going to try this!
Old Feb 9, 2003 | 11:00 PM
mrr23's Avatar
Engine: 360 HSR
just be sire when you do this, you don't ruin the little hole where the grease fitting will go. use a socket the diameter of the ball joint. or something flat all the way across the bottom of the ball joint like in the pic. last thing you want is to get the ball joint in only to find out you ruined that area.
Old Feb 9, 2003 | 11:23 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
nice, but i wish the pics were clearer... no worries about craching **** with the big a$$ hammer?
Old Feb 9, 2003 | 11:25 PM
mrr23's Avatar
Engine: 360 HSR
yeah my camera sucks. if you can crack a control arm with a 10# hammer, you're better than i am. done it to 4 cars already including my own.
Old Feb 10, 2003 | 11:27 AM
HamSpiced's Avatar
yeah well whenever im fixing my car Murphy's Law always applies......
Old Feb 10, 2003 | 11:50 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Go with the press. They are free rentals at Auto Zone and make the job simple. You jsut give a deposit which is refunded when you return the tool.
Old Feb 10, 2003 | 01:33 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Hmmm.....
Is it a huge PITA if I already have the A-arm off of the car??? I am gonna be putting new bushings on my car all the way around, should I do this with the A-arm installed or off of the car??
Old Feb 10, 2003 | 09:11 PM
mrr23's Avatar
Engine: 360 HSR
with the arm off, then i'd use a press. because you have nothing to hold the arm still. you have to make sure the ball joint is straight when using a press. i've seen presses come flying off if not set properly.
Old Feb 10, 2003 | 10:32 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Right...
But I was just asking whether it is easier to use a press or to do it with your method? See, I could just re-install them after I put the new bushings in, or I can use the press while they are off. Which is quicker/easier?
Old Feb 11, 2003 | 09:21 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Wher you at?
C'mon mrr23, what happened to ya?
Old Feb 11, 2003 | 09:58 PM
laiky's Avatar
In some cases the ball joints have been replaced a bunch of times and they will hammer out easily and can go back in with some moderat tapping. In others they will be very tight coming out and may **** going in. get the press, especially if its free. If you can hammer them in and out easily do it, if not use the press. I prefer the press ( its sometimes harder than hammering) but it doesn't maul the control arms.
one more note, i got the heavy duty tie rod adjusting sleeves from global west, i think they are well worth the cost.
Old Feb 12, 2003 | 07:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Also use some anti-seize or moly lube on the ball joint where it presses in. It will help in pressing it in.
Ditto on the tie rod adjusting sleeves.
RBob.
Old Feb 12, 2003 | 09:34 AM
laiky's Avatar
definately on the adjusting sleeves! plus your alignment guy will love you for it.
Old Feb 12, 2003 | 07:44 PM
CamaroZ_85's Avatar
I think it is WAY easier to use a press than a hammer. The press is a no-brainer as long as you set the cups up properly. It might slip off, but it wont come flying out. Certrainly doesnt pose more of a threat than beating the control arm w/ a hammer while there is a jack supporting the arm to keep the spring in place. I would imagine that you have more of a chance "cocking" the balljoint while hammering it than pressing it. Anyway, if you have the arm off the car a press is certainly the way to go. If you cant get ahold of the press, hammering on the car is an alternative. Personally, I did it with a press and an impact gun and it took about 10 seconds to get it out and 30 to get it back in. On a side note, be careful getting the bushings out/in because its pretty easy to squish the fingers on the arm where the bushings are held in.
customblackbird
Aug 15, 2021 10:16 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
BlackTopKing
Aug 19, 2015 12:13 PM
jbd1969
Aug 17, 2015 07:06 PM
NBrehm
Aug 5, 2015 07:57 PM
