RUMOR: Caprice and 1LE??
Old Feb 9, 2003 | 10:48 AM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Could be totally wrong here, but I think I read or heard somewhere, that some late 80's early 90's Caprices had either a 1LE setup or something very similar. Wondering if a salvage yard caprice might deliver a 1LE.
Has anyone ever heard this before?
Old Feb 9, 2003 | 10:53 AM
Ok here's the story....pretty good history.
http://chuckb.1le.net/1le_history.html
Old Feb 10, 2003 | 10:22 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
the article simply said that 1LE camaros used caprice rotors. caprices didnt get the PBR calipers
Old Feb 10, 2003 | 11:31 AM
LeftTurn1LE's Avatar
Yep, the 1LE uses re-drilled Caprice rotors and Corvette calipers. The rotors off a junkyard Caprice won't necessarily fit a Camaro.
Old Feb 10, 2003 | 05:19 PM
kevosiroc's Avatar
LeftTurn1LE Yep, the 1LE uses re-drilled Caprice rotors and Corvette calipers. The rotors off a junkyard Caprice won't necessarily fit a Camaro
For the record, the calipers are not the same. The camaro calipers are wider.
Old Feb 10, 2003 | 05:25 PM
Ratchet's Avatar
I saw an article in one of the Hot Rod Rags that talked about 90's police version of the caprice being equiped with 1LE brake set up front and rear.
Ric
Old Feb 10, 2003 | 06:21 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Hmmm, this is very interesting. I happen to have an old 1990 caprice ex cop car sitting in my back yard. I'll have to go check this out!!
Old Feb 10, 2003 | 08:53 PM
Didn't know that. Thanks for the correction.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
CatmanFS
Sep 19, 2015 09:00 AM
BLK87Z
Sep 18, 2015 11:29 PM
Strick1
Sep 6, 2015 10:38 AM
