Have Test Repot: Third Gen .99g skid pad
Old Feb 16, 2003 | 03:36 AM
wavslav's Avatar
VSE by Matt Adams, a specialty Equipment Company started by Matt and Dad, Herb Adams (you BETTER know who Herb is!!!)
designs and manufactures race parts for F bodies among many other interesting products, (They will build you a custom one off car if you want, race or street)
Carmel Valley, CA.
831 659 7660
Has a test report in the VSE catalog:
Stock '82 Firebird w 215x65-15 goodyears = .82g
installed 245x60-15 tires = .85g
Installed VSE sway bars= .88g
cut 1/2, coil front spring, .92g
added steel front control arm bushings
AX alignment, rear sway bar bushings, .96g
relocate battery to trunk
swap 255-50x16 goodyear on 16x8 wheels .99g
this is old data, I bet my racecar is capable of way more then these numbers
Old Feb 21, 2003 | 03:23 PM
377Z's Avatar
Car: 2007 Volvo S60R, 2005 Audi A4
Engine: 300HP 2.5L I5, 200HP 2.0L I4
Transmission: TF-80SC, Getrag 6 speed
Axle/Gears: 3.33:1, 3.54:1
I have a 1988 Camaro VS. Mustang issue of Road and Track that details the 1985 V6 sport coupe he bought for his wife. In short, it says they wanted to maintain the V6 mileage, but wanted to improve the car's handling--thus the VSE package was born. Article states the car averaged 1.01G, with 1.02G best. Slalom was only 66.6MPH. I say *only* because there is another thread floating around here with a similar slalom speed but ~0.95G best. Details on the car:
255/50ZR-16 shaved tread S compound showroom stock race rubber on 9" wide rims
33mm front, 28.5mm rear bars
'shortened' stock springs (does not say how much in this article)
'aluminum/nylon hybrid' bushings
'specially valved' shocks
battery moved to rear
Also, since this was his wifes car, it says it had 50,000 miles on it at the time of the test, and Road and Track went on to say ride did not belay the cars incredible capabilities--it rode well. I'm sure further tweaking of the spring/shock combo to work more in concert with the sway bars would improve transient response and raise slalom speed.
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Vintageracer
Aug 11, 2015 08:13 PM
