Can 4th gen corvette calipers be modified to fit a 3rd gen camaro?
Old Feb 16, 2003 | 02:12 PM
IROC_Canuck's Avatar
does anyone know, just for the fronts?
Old Feb 16, 2003 | 05:36 PM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
I'm going to do it some time in the future, calipers are cheap, $90 a piece I think. I was contemplating a dual caliper setup... Anyone correct me if I'm wrong, but unless the rotors can get rid of the heat, extra calipers and brake pad surface would be a bad thing, right? There is also the issue of getting enough fluid volume to run 4 calipers in the front instead of 2 smaller ones.
I was thinking a bracket to hold the caliper, bolting on the original location, and a corvette rotor (which doesn't have a hub) bolted to a factory 3rd gen front rotor with the disc turned off. With longer studs of course, hmm, then I wouldn't need wheel spacers up front either...
Old Feb 16, 2003 | 09:52 PM
hmm, when you doing this, cause i would like to copy it, or i will just go with wilwood, i dont know
Old Feb 17, 2003 | 05:02 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Ive got a set of Baer Racing brakes which use the ZR1 caliper and 13"rotor.You need to fabricate a special bracket and modify your spindles to fit them but if you buy Baer it comes ready to bolt straight on.
cheers
PM
Old Feb 17, 2003 | 06:11 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I did alot of reacearch on this:
Here are my previous posts about it, which explain how to do it:
https://www.thirdgen.org/techbb2/sho...hreadid=142115
https://www.thirdgen.org/techbb2/sho...hreadid=132513
And here is sites with good info.
http://home.earthlink.net/~kiszka/C5_brake_upgrade.htm
http://home.cfl.rr.com/shuhy/brakes.htm
Old Feb 18, 2003 | 12:44 PM
i read most of all that is in there, which is alot of crap, i have a few questions, if i cut off the 'ears' fromt he spindles, and i got corvette rotors and calipers could i jut throw them on? what other mods would hav to be done, and does someone have a pic of what the hub looks like? i have 4 wheel discs so i have the right proportional valve i believe
Old Feb 18, 2003 | 01:00 PM
Spifz's Avatar
It seems that the caliper won't bolt up to our spindles, somebody mentioned that the bolt distance on the Corvette calipers is 5in? That is what the plate is for, and to move the caliper out further to accomidate the larger rotor. Honestly, the plate is not complicated, someone who doesn't have a mill could probably get by with a cardboard template and a drillpress. Although I would make mine on the mill. As far as the rotors, if you wanted to, you could saw and grind your current rotors off the hub, press in longer studs, and slap a vette rotor on that. You would get some extra wheel spacing, .600 or .300 as someone indicated, but as long as your bracket put the caliper in the right position, it would be all good.
I think the plates Baer sent me for the caliper mounts in the back were 5/16 thick. 5/16 (steel) and some 10.9 or grade 8 hardware should be plenty strong up front .
Old Feb 18, 2003 | 01:03 PM
Spifz's Avatar
Anyone have any ideas about the heat dissipation issue with running dual calipers? (mentioned above)
Is it a problem getting enough fluid volume to run Corvette calipers with our master cylinders? Would it be a problem to get enough volume to run the extra calipers?
I would do it for a cool factor Then I'd have to get some super skinny spoke 19 inch wheels to show em off...
Old Feb 18, 2003 | 02:27 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
If you actually read all the "crap" (according to you) then you would not ask this. With all these links, almost everything is explained.
I see in my other post you just made a post asking what a hub is. This is just proof you didn’t even take the time to read these links thoroughly before dismissing them as “crap”.
Old Feb 18, 2003 | 02:52 PM
so i have to make a hub? what is a hub?and what is the size of the corvette rotors compared to an irocs?
Old Feb 18, 2003 | 03:01 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I just answered your hub question in the other post, check it out.
The corvette NONE-HD rotors are 12 inches. Not sure about the stock IROC ones
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Vintageracer
Aug 11, 2015 08:13 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
