Anyone Notice A Decent Traction Improvement After You Installed Sfc's???
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Just wondering cause since i have installed mine the launch and 1-2 shift is much better. Not to mention I can no longer chirp 2-3. Since the body is staying straight it lifts and launches much more evenly, so the 255's are hooking much better.
What about the rest of you???
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I feel like an idiot. SOTP??
As for SFC's, oh yeah. I want'em bad on my GTA. I really want to just mod the hell out of the chassis so I can corner on rails. I'm really more into autocross then drag. But there is something to be said for trying to accelorate as fast as you can in a straight line.^_^
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Here's an earlier post of mine-
[I have Spohn solid bar combo 34mm/25mm (34mm =1 5/16" / 25mm = 1") on my V6and the *** end is slightly loose now after installing his subframe connecters. The inside rears are lifting a bit too much now with the more rigid chassis. I'm going to opt for a smaller rear bar like your solid 7/8" to keep the rear planted. Also remember, I have a lightweight V6 up front with 800Lb springs and I'm still lifting the rear. This would be way worst with a heavier V8 car that I believe stock runs about 650-700 lb springs. If I had a V8 in MY car the way it is setup I would opt for a 36mm Solid front bar if I could find one (otherwise go up a bit in spring rate with the 34mm- probably as high as 1100Lb springs- Can you say hard ride on the street) and I would buy the 7/8"solid for the rear. 25mm solid (1") is too big for the rear of these cars under any circumstance.]
The car actually handled better before I installed the Spohn SFC's with the combo was running. I now have to rework it a bit do to lack of chassis flex lifting the rears. It will handle better than before eventually when I get the bugs worked out.
Car: 91' RS
Engine: Built 355
Geeezz...
Originally posted by Z28DJP1987
Your new SFC's will do wonders for the SOTP feel.
So apparently there is a traction improvement after installing sfc's?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
SOTP = Seat Of The Pants
and when i installed mine, i can't say that i gained any traction, but the car much more solid. and i could feel a huge a diffrence.
Car: blue 84 z28
Engine: mildly modified 350
I had the same experience: lauching was a lot straighter and the car just felt more solid and was more predictable. Also, they are an awesome place to utilize as a jacking point....
