How hard is it to replace the frame in our cars?
Old Feb 24, 2003 | 04:43 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
my '84s rocker panels pretty much rotted out... hence it's retirement... right now the engine has been removed and just about the entire front clip... I am either going to part it out or tear it all the way down and do what's necessary to build a good solid frame for ~500 Hp... If it is possible I'd like to use my '84 for the basis, but if not I'll have to find some 4 or 6 banger '82-84 and build off of that.
thanks in advance
Old Feb 24, 2003 | 06:50 PM
Marc 85Z28's Avatar
You do realize you have a unibody car right? There is no true frame.
Old Feb 24, 2003 | 07:34 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Yes I realize that... it is a problem yes... but is it possible to replace the rocker panels? I was wondering how hard it might be to build up a frame and stick the body on that... I should really let this car just die peacefully, but I'd imagine something like this would be just the ticket for a 500 Hp build up... I have no need for this car to be on the road so I got all the time in the world, and eventually enough money.
The big question here is can I adapt a good unibody better than just flat out fabricating it?
Old Feb 24, 2003 | 08:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any part of the body including rocker panels can be changed.
To change the unibody to some sort of full frame will cost more than the car is worth. A complete tube chassis should start at around $10,000. It's not the parts but the labour needed to do it.
I'd love to tube chassis my car but the expense says I stay with what I got.
Start with a good foundation. I spent more money than I wanted when I bought my car but the body was in mint condition. No dents, no rust etc. For what it costs to fix up a poor body, you can spend the extra money to find a body in good condition and probably save money.
Old Feb 24, 2003 | 08:24 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Guess I'll keep takin stuff off then LOL I'm sure I can find a good body floating around... there's a lot of good parts on this car though... The junkyard ain't getting more than a carcus when they tow this sucker away.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jharrison5
Aug 19, 2015 05:53 PM
squiggy2
Aug 9, 2015 09:30 PM
Fronzizzle
Aug 9, 2015 01:15 PM
