Shock problems
Old Feb 24, 2003 | 05:08 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Shock problems
Pretty sure I have original shocks on my car, 88 Iroc-Z 305 5spd. Anyways, my front tires rub bad when i turn hard, parking it is a joke. If I look at the stance form the side, i notice the back looks like its sitting up a little bit higher then the front. Also when i go over bumps it shoulds like my spare tire is loose cause i hear some "banging" noises, its hard to explain. Anyone have any ideas? I have the right size tires and what not, so im thinking my shocks are worn causing me to sit lower, and therefor making my front tires rub.
Old Feb 27, 2003 | 01:56 AM
MdFormula350's Avatar
could be very worn out springs also, did you look at those at all?
Old Feb 27, 2003 | 02:33 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Dude throw in the towel and rebuild all of the suspension / steering, poor car is old and needs it, bring it over i'll help you do it.
Old Feb 27, 2003 | 03:56 PM
82camaro's Avatar
Car: 82 camaro SC
The shocks don't hold up the car, the springs do. Worn out shocks can cause some noises and/or bottoming out sounds. You don't have shocks on the front, they are struts. They don't hold up the car either. Rubbing at full lock was fairly common when these cars were brand new. Tire width varies from brand to brand of the same size, you might have a set that is a bit wider. Shocks, struts, and springs will make it drive like a different car.
customblackbird
Aug 15, 2021 10:16 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
